| » Broiler come on when oven control is turned to warm |
Model Number: jbp26gs2wh Brand: GE Age: More than 10 years
When we use the oven and set temp to any oven range the Broiler turns on. I think it is the control. The part number indicates that GE do not make it anymore.
I am not sure that you have a problem.
I went to the GE site and looked at the operators manual unfortunately it was pretty useless. Most ovens use the broil element during preheat and may even switch back and forth between the bake and broil elements after preheat as this provides a more even heat in the oven. I the unit gets to the set temperature and regulates the temperature and cooks/bakes OK then the unit is working correctly. Note: Getting tech info on a GE is very difficult, they like to keep this info a secret.
__________________
| Display Modes | |
| Broiler does not stay on, oven only warm | CookieMonster | Oven Repair (including Ranges and Cooktops) | 0 | 02-13-2009 11:54 AM |
| Oven turned on by itself | jbhurt | Oven Repair (including Ranges and Cooktops) | 1 | 10-11-2008 06:02 PM |
| Broiler barely gets warm | jne | Oven Repair (including Ranges and Cooktops) | 3 | 09-17-2008 03:47 PM |
| Clock turns on when the oven is turned on but oven doesn't work | LMesey | Oven Repair (including Ranges and Cooktops) | 2 | 08-22-2008 11:20 AM |
| oven/broiler control unit | dynaguy | Oven Repair (including Ranges and Cooktops) | 1 | 07-31-2007 04:36 PM |
