Appliance Repair Forum
-   Oven Repair (including Ranges and Cooktops) (http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/)
-   -   Oven won't heat properly (http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/80851-oven-wont-heat-properly.html)
pocahontas 02-25-2010 07:52 AM
In order to get the temperature to 350 degrees, i have to set it at 515 degrees and it takes forever to get to 350. I use an oven thermometer to see what the temperature is. Although this is an older model, it has been used very little over the years. Could it just be a sensor or something like that??
magician59 02-25-2010 08:39 AM
Check the oven sensor. A good one will show 1100-1300 ohms, depending on the ambient temperature.
