Discuss
The Fan Oven will not heat up
 in
hi my oven has just stop heating up, the fan is fine the grill is fine, the oven element is
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » The Fan Oven will not heat up
  By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 02-24-2010, 06:24 AM
Junior Member
pgmbmc is on a distinguished road
Default The Fan Oven will not heat up
Brand: -brand-   Age: 1 - 5 years
hi
my oven has just stop heating up, the fan is fine the grill is fine, the oven element is not heating up, the power supply to the element is fine as I checked this, need to know if it is the element or the thermostat, many thanks.
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Wall oven will not heat/re-heat properly dottavio Oven Repair (including Ranges and Cooktops) 0 01-07-2010 09:47 AM
Oven/clock Control Panel is no longer lit but oven does heat. jthomas@abrakadoodle.com Oven Repair (including Ranges and Cooktops) 1 12-05-2009 04:07 PM
Oven broiler and burners work - oven will not heat fatbuford Oven Repair (including Ranges and Cooktops) 0 11-27-2009 05:50 AM
Caloric double oven/bottom oven doesn't heat kj0505 Oven Repair (including Ranges and Cooktops) 1 12-10-2008 09:14 AM
Bosch 27" Dbl oven Powering on but no heat either oven badace Oven Repair (including Ranges and Cooktops) 0 12-02-2007 09:56 AM
