Discuss
Thermocouple problem on RV oven
 in
My partner was doing some testing for gas leaks and messed up the oven in our 5th wheel trailer. It'
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Thermocouple problem on RV oven
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 05-17-2008, 06:19 PM
sillycat41 sillycat41 is offline
Junior Member
sillycat41 is on a distinguished road
Default Thermocouple problem on RV oven
Model Number: 22-RW-4-49   Brand: Magic Chef   Age: More than 10 years
My partner was doing some testing for gas leaks and messed up the oven in our 5th wheel trailer. It's a Magic Chef 4 burner oven, model
He unscrewed the silver nut that holds the thermocouple to the back of the oven control. Didn't come apart as he planned, but after he re-tightened the nut, there are now two problems:
1. Now when the oven pilot light is turned on, there is gas all the time to the pilot... like the thermocouple is "hot".
2. Also the secondary pilot and main oven burner doesn't come on until the dial is turned 450 degrees. Anything less than that shuts the burner off, but the pilot stays lit with the control set at pilot on. The pilot does go out when you turn the knob to off.
Is there a way to adjust the thermocouple that goes into the back of the oven control?? Does it slide in all the way? It hasn't worked right since he unscrewed the silver nut.
Thanks in advance.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
top oven problem stever Oven Repair (including Ranges and Cooktops) 0 04-14-2008 11:29 AM
Thanksgiving Oven Problem.....its still a Problem! rbmattila Oven Repair (including Ranges and Cooktops) 1 03-03-2008 09:05 AM
oven problem bookie Oven Repair (including Ranges and Cooktops) 0 02-19-2008 11:27 AM
replacement cone thermocouple not available?? LindaP Oven Repair (including Ranges and Cooktops) 1 01-29-2008 05:48 PM
Which thermocouple? Pilot is on, oven won't light docnpat Oven Repair (including Ranges and Cooktops) 1 12-31-2007 01:32 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
