Discuss
Oven doesn't shut off
 in
My Kitchen Aid Oven worked great when I first got it but now it won't turn off unless I
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Oven doesn't shut off
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 05-16-2008, 10:05 AM
Hamiltons Hamiltons is offline
Junior Member
Hamiltons is on a distinguished road
Post Oven doesn't shut off
Model Number: KESA907PBL00   Brand: Kitchen Aid   Age: 1 - 5 years
My Kitchen Aid Oven worked great when I first got it but now it won't turn off unless I push the Cook Duration buton and then press 1 for 1 minute and then hit start. If I make an error in the timing I have to repeat it again. It took a lot of trial and error to figure out how to do this procedure to find something that would work. The off button just doesn't do anything and neither does the regular timer.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 05-16-2008, 07:19 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Most likely the problem is a bad membrane switch. In order to provide the right part number I need the color of the control panel.
__________________
Professional appliance repair services in Orange County, California.
  #3 (permalink)
Old 05-18-2008, 09:39 AM
Junior Member
Default
The oven control panel is black with small circles around each of the items.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
my oven is shut down munequita4u2 Oven Repair (including Ranges and Cooktops) 7 05-29-2008 12:49 PM
Oven will not shut off kevker Oven Repair (including Ranges and Cooktops) 0 04-26-2008 06:09 AM
Oven Won't Shut Off. ardonato@msn.com Oven Repair (including Ranges and Cooktops) 0 02-12-2008 04:12 PM
Oven Won't Shut Off RickG Oven Repair (including Ranges and Cooktops) 1 01-21-2008 10:56 AM
Oven will not shut off jhoium Oven Repair (including Ranges and Cooktops) 3 10-02-2007 01:32 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
