Discuss
Bosch igniter
 in
The igniter on the back right side continues to spark after a flame . I assume the module is bad. Is
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Bosch igniter
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 05-16-2008, 09:56 AM
dsr4866 dsr4866 is offline
Junior Member
dsr4866 is on a distinguished road
Default Bosch igniter
Model Number: NHT 722 A UC   Brand: Bosch   Age: 5 - 10 years
The igniter on the back right side continues to spark after a flame . I assume the module is bad. Is there anything else I should look for?
David
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 05-16-2008, 07:15 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
David,
The spark module is the last part I would think about.
The first thing I would do is make sure the igniter is clean from grease, not damaged and properly aligned. Then check if the burner is properly grounded.
Here are the break down diagrams for the Bosch cook top Model NHT722
__________________
Professional appliance repair services in Orange County, California.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Igniter Malfunction hec2832pa Oven Repair (including Ranges and Cooktops) 0 04-23-2008 08:41 AM
igniter gibby289 Oven Repair (including Ranges and Cooktops) 3 04-08-2008 08:17 PM
igniter issue maisoe Dryer Repair 2 11-14-2007 04:59 PM
Igniter Deb Oven Repair (including Ranges and Cooktops) 0 10-21-2007 08:09 AM
Igniter Deb Oven Repair (including Ranges and Cooktops) 0 10-21-2007 08:01 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
