Discuss
Wiring Oven Thermostat
 in
I just bought a Zodiac Model BT-C335-39 Oven Thermostat on ********. This model is made in Canada and was in
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Wiring Oven Thermostat
  #1 (permalink)
Old 05-15-2008, 12:47 PM
Junior Member
lbosma is on a distinguished road
Default Wiring Oven Thermostat
Model Number: BT-C335-39   Brand: -other-   Age: Less than 1 year
I just bought a Zodiac Model BT-C335-39 Oven Thermostat on ********. This model is made in Canada and was in a Sears box so I assume it can replace a Kenmore oven. I need to wire this unit into a warming oven I use to make plastic vacuum mold parts. I started out by using some lower wattage units and they didn't work. I just need to know how to wire this unit in. It is 110 V and has 3 lugs marked 2, 4 and 6 on one side of the dial and 3 lugs marked 1, 5 and 7 on the other. It has a thermocouple running down the middle. I just don't have a diagram for this and it didn't come with one. I am assuming that one set of numbers is black, neutral and ground and the other side is the same connected to my burners. Can you send me a wiring diagram or simply tell me how to wire this unit to the burners. I am only using it to control the burners. There is no light or timer on it either. Thanks,
Ads By Google
Related Models
Magic Chef BT16JA-3 Rv Range - Gas
Magic Chef BT16JA-3T Rv Range - Gas
Magic Chef BT16JA-3Z Rv Range - Gas
Magic Chef BT16JA-4 Rv Range - Gas
Magic Chef BT16JA-4T Rv Range - Gas
Magic Chef BT16JA-4TZ Rv Range - Gas
Magic Chef BT16JA-4Z Rv Range - Gas
Magic Chef BT16JK-3 Rv Range - Gas
Magic Chef BT16JK-3T Rv Range - Gas
Magic Chef BT16JK-3Z Rv Range - Gas
Magic Chef BT16JK-4 Rv Range - Gas
Magic Chef BT16JK-4T Rv Range - Gas
Magic Chef BT16JK-4TZ Rv Range - Gas
Magic Chef BT16JK-4Z Rv Range - Gas
Magic Chef BT16JN-3T Rv Range - Gas
Magic Chef BT16JS-3 Rv Range - Gas
Magic Chef BT16JS-3T Rv Range - Gas
Magic Chef BT16JS-3Z Rv Range - Gas
Magic Chef BT16JS-4 Rv Range - Gas
Magic Chef BT16JS-4T Rv Range - Gas
Magic Chef BT16JS-4TZ Rv Range - Gas
Magic Chef BT16JS-4Z Rv Range - Gas
Magic Chef BT16KA-3 Rv Range - Gas
Magic Chef BT16KA-3S Rv Range - Gas
Magic Chef BT16KA-4 Rv Range - Gas
Magic Chef BT16KA-4S Rv Range - Gas
Magic Chef BT16KA-4ST Rv Range - Gas
Magic Chef BT16KA-4T Rv Range - Gas
Magic Chef BT16KK-3 Rv Range - Gas
Magic Chef BT16KK-3S Rv Range - Gas
Magic Chef BT16KK-4 Rv Range - Gas
Magic Chef BT16KK-4S Rv Range - Gas
Magic Chef BT16KK-4ST Rv Range - Gas
Magic Chef BT16KK-4T Rv Range - Gas
Magic Chef BT16KN-3 Rv Range - Gas
Magic Chef BT16KN-3S Rv Range - Gas
Magic Chef BT16KN-4 Rv Range - Gas
Magic Chef BT16KN-4S Rv Range - Gas
Magic Chef BT16KN-4ST Rv Range - Gas
Magic Chef BT16KN-4T Rv Range - Gas
Magic Chef BT16KS-3 Rv Range - Gas
Magic Chef BT16KS-3S Rv Range - Gas
Magic Chef BT16KS-4 Rv Range - Gas
Magic Chef BT16KS-4S Rv Range - Gas
Magic Chef BT16KS-4ST Rv Range - Gas
Magic Chef BT16KS-4T Rv Range - Gas
Magic Chef BT16KY-4 Rv Range - Gas
Magic Chef BT16LA-3 Rv Range - Gas
Magic Chef BT16LA-3Z Rv Range - Gas
Magic Chef BT16LA-4 Rv Range - Gas
Magic Chef BT16LA-4T Rv Range - Gas
Magic Chef BT16LA-4TZ Rv Range - Gas
Magic Chef BT16LA-4Z Rv Range - Gas
Magic Chef BT16LK-3 Rv Range - Gas
Magic Chef BT16LK-3Z Rv Range - Gas
Magic Chef BT16LK-4 Rv Range - Gas
Magic Chef BT16LK-4T Rv Range - Gas
Magic Chef BT16LK-4TZ Rv Range - Gas
Magic Chef BT16LK-4Z Rv Range - Gas
Magic Chef BT16LN-3 Rv Range - Gas
Magic Chef BT16LN-3Z Rv Range - Gas
Magic Chef BT16LN-4 Rv Range - Gas
Magic Chef BT16LN-4T Rv Range - Gas
Magic Chef BT16LN-4TZ Rv Range - Gas
Magic Chef BT16LN-4Z Rv Range - Gas
Magic Chef BT16LS-3 Rv Range - Gas
Magic Chef BT16LS-3Z Rv Range - Gas
Magic Chef BT16LS-4 Rv Range - Gas
Magic Chef BT16LS-4T Rv Range - Gas
Magic Chef BT16LS-4TZ Rv Range - Gas
Magic Chef BT16LS-4Z Rv Range - Gas
Magic Chef BT16LY-3 Rv Range - Gas
Magic Chef BT16LY-4 Rv Range - Gas
Magic Chef BT16LY-4T Rv Range - Gas
Magic Chef BT16LY-4TZ Rv Range - Gas
Magic Chef BT16LY-4Z Rv Range - Gas
Magic Chef BT16MA-3 Rv Range - Gas
Magic Chef BT16MA-3T Rv Range - Gas
Magic Chef BT16MA-3Z Rv Range - Gas
Magic Chef BT16MA-4 Rv Range - Gas
Magic Chef BT16MA-4T Rv Range - Gas
Magic Chef BT16MA-4TZ Rv Range - Gas
Magic Chef BT16MA-4Z Rv Range - Gas
Magic Chef BT16MK-3 Rv Range - Gas
Magic Chef BT16MK-3T Rv Range - Gas
Magic Chef BT16MK-3Z Rv Range - Gas
Magic Chef BT16MK-4 Rv Range - Gas
Magic Chef BT16MK-4T Rv Range - Gas
Magic Chef BT16MK-4TZ Rv Range - Gas
Magic Chef BT16MK-4Z Rv Range - Gas
Magic Chef BT16MN-3 Rv Range - Gas
Magic Chef BT16MN-3T Rv Range - Gas
Magic Chef BT16MN-3Z Rv Range - Gas
Magic Chef BT16MN-4 Rv Range - Gas
Magic Chef BT16MN-4T Rv Range - Gas
Magic Chef BT16MN-4TZ Rv Range - Gas
Magic Chef BT16MN-4Z Rv Range - Gas
Magic Chef BT16MS-3 Rv Range - Gas
Magic Chef BT16MS-3T Rv Range - Gas
Magic Chef BT16MS-3Z Rv Range - Gas
Magic Chef BT16MS-4 Rv Range - Gas
Magic Chef BT16MS-4T Rv Range - Gas
Magic Chef BT16MS-4TZ Rv Range - Gas
Magic Chef BT16MS-4Z Rv Range - Gas
Magic Chef BT16MY-3 Rv Range - Gas
Magic Chef BT16MY-3T Rv Range - Gas
Magic Chef BT16MY-3Z Rv Range - Gas
Magic Chef BT16MY-4 Rv Range - Gas
Magic Chef BT16MY-4T Rv Range - Gas
Magic Chef BT16MY-4TZ Rv Range - Gas
Magic Chef BT16MY-4Z Rv Range - Gas
Magic Chef BT16NA-3 Rv Range - Gas
Magic Chef BT16NA-3T Rv Range - Gas
Magic Chef BT16NA-3Z Rv Range - Gas
Magic Chef BT16NA-4 Rv Range - Gas
Magic Chef BT16NA-4T Rv Range - Gas
Magic Chef BT16NA-4TZ Rv Range - Gas
Magic Chef BT16NA-4Z Rv Range - Gas
Magic Chef BT16NK-3 Rv Range - Gas
Magic Chef BT16NK-3T Rv Range - Gas
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Thermostat wiring wrktem Dryer Repair 0 02-04-2010 10:39 AM
New thermostat won't plug into wiring. Jim Roethler Oven Repair (including Ranges and Cooktops) 3 10-21-2009 12:36 PM
New thermostat won't plug into wiring. Jim Roethler Oven Repair (including Ranges and Cooktops) 3 10-20-2009 09:24 PM
thermostat wiring question rickatthelake Refrigerator & Freezer Repair 2 05-06-2009 02:16 PM
Thermostat Wiring Diagram szymanski1 Oven Repair (including Ranges and Cooktops) 1 02-15-2008 12:57 PM
