Discuss
safety gas valve
 in
The gas valve controlls both the broiler and bake in the oven. Broiler works fine but the bake heats really
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » safety gas valve
  #1 (permalink)
Old 05-15-2008, 08:46 AM
Junior Member
jan and tom is on a distinguished road
Default safety gas valve
Model Number: 76-4960-23/04   Brand: Tappan   Age: More than 10 years
The gas valve controlls both the broiler and bake in the oven. Broiler works fine but the bake heats really slow, take like an hour to heat to 300. You have the valve in stock just want to make sure that could be the problem.
Related Models
Frigidaire 76-4967-00-01 Tap(v1) / Gas Range
Frigidaire 76-4967-00-02 Tap(v5) / Gas Range
Frigidaire 76-4967-00-03 Tap(v9) / Gas Range
Frigidaire 76-4967-00-04 Tap(v1) / Gas Range
Frigidaire 76-4967-00-05 Tap(v5) / Gas Range
Frigidaire 76-4967-00-06 Tap(v9) / Gas Range
Frigidaire 76-4967-00-07 Tap(v1) / Gas Range
Frigidaire 76-4967-00-08 Tap(v9) / Gas Range
Frigidaire 76-4967-00-09 Tap(v1) / Gas Range
Frigidaire 76-4967-00-10 Tap(v9) / Gas Range
Frigidaire 76-4967-00-11 Tap(v1) / Gas Range
Frigidaire 76-4967-00-12 Tap(v1) / Gas Range
Frigidaire 76-4967-00-13 Tap(v1) / Gas Range
Frigidaire 76-4967-18-04 Tap(v4) / Gas Range
Frigidaire 76-4967-18-05 Tap(v8) / Gas Range
Frigidaire 76-4967-18-06 Tap(v12) / Gas Range
Frigidaire 76-4967-23-01 Tap(v2) / Gas Range
Frigidaire 76-4967-23-02 Tap(v6) / Gas Range
Frigidaire 76-4967-23-03 Tap(v10) / Gas Range
Frigidaire 76-4967-23-04 Tap(v2) / Gas Range
Frigidaire 76-4967-23-05 Tap(v6) / Gas Range
Frigidaire 76-4967-23-06 Tap(v10) / Gas Range
Frigidaire 76-4967-23-07 Tap(v2) / Gas Range
Frigidaire 76-4967-23-08 Tap(v10) / Gas Range
Frigidaire 76-4967-23-09 Tap(v2) / Gas Range
Frigidaire 76-4967-23-10 Tap(v10) / Gas Range
Frigidaire 76-4967-23-11 Tap(v2) / Gas Range
Frigidaire 76-4967-23-12 Tap(v2) / Gas Range
Frigidaire 76-4967-23-13 Tap(v2) / Gas Range
Frigidaire 76-4967-32-07 Tap(v4) / Gas Range
Frigidaire 76-4967-32-08 Tap(v12) / Gas Range
Frigidaire 76-4967-32-09 Tap(v4) / Gas Range
Frigidaire 76-4967-32-10 Tap(v12) / Gas Range
Frigidaire 76-4967-32-11 Tap(v4) / Gas Range
Frigidaire 76-4967-32-12 Tap(v4) / Gas Range
Frigidaire 76-4967-32-13 Tap(v4) / Gas Range
Frigidaire 76-4967-66-01 Tap(v3) / Gas Range
Frigidaire 76-4967-66-02 Tap(v7) / Gas Range
Frigidaire 76-4967-66-03 Tap(v11) / Gas Range
Frigidaire 76-4967-66-04 Tap(v3) / Gas Range
Frigidaire 76-4967-66-05 Tap(v7) / Gas Range
Frigidaire 76-4967-66-06 Tap(v11) / Gas Range
Frigidaire 76-4967-66-07 Tap(v3) / Gas Range
Frigidaire 76-4967-66-08 Tap(v11) / Gas Range
Frigidaire 76-4967-66-09 Tap(v3) / Gas Range
Frigidaire 76-4967-66-10 Tap(v11) / Gas Range
Frigidaire 76-4967-66-11 Tap(v3) / Gas Range
Frigidaire 76-4967-66-12 Tap(v3) / Gas Range
Frigidaire 76-4967-66-13 Tap(v3) / Gas Range
Frigidaire 76-8667-00-01 Tap(v9) / Gas Range
Frigidaire 76-8667-00-02 Tap(v13) / Gas Range
Frigidaire 76-8667-00-03 Tap(v9) / Gas Range
Frigidaire 76-8667-00-04 Tap(v13) / Gas Range
Frigidaire 76-8667-00-05 Tap(v13) / Gas Range
Frigidaire 76-8667-00-06 Tap(v17) / Gas Range
Frigidaire 76-8667-00-07 Tap(v5) / Gas Range
Frigidaire 76-8667-00-08 Tap(v9) / Gas Range
Frigidaire 76-8667-08-01 Tap(v12) / Gas Range
Frigidaire 76-8667-08-02 Tap(v16) / Gas Range
Frigidaire 76-8667-23-01 Tap(v10) / Gas Range
Frigidaire 76-8667-23-02 Tap(v14) / Gas Range
Frigidaire 76-8667-23-03 Tap(v10) / Gas Range
Frigidaire 76-8667-23-04 Tap(v14) / Gas Range
Frigidaire 76-8667-23-05 Tap(v14) / Gas Range
Frigidaire 76-8667-23-06 Tap(v18) / Gas Range
Frigidaire 76-8667-23-07 Tap(v6) / Gas Range
Frigidaire 76-8667-23-08 Tap(v10) / Gas Range
Frigidaire 76-8667-32-03 Tap(v12) / Gas Range
Frigidaire 76-8667-32-04 Tap(v16) / Gas Range
Frigidaire 76-8667-32-05 Tap(v16) / Gas Range
Frigidaire 76-8667-32-06 Tap(v20) / Gas Range
Frigidaire 76-8667-32-07 Tap(v8) / Gas Range
Frigidaire 76-8667-32-08 Tap(v12) / Gas Range
Frigidaire 76-8667-66-01 Tap(v11) / Gas Range
Frigidaire 76-8667-66-02 Tap(v15) / Gas Range
Frigidaire 76-8667-66-03 Tap(v11) / Gas Range
Frigidaire 76-8667-66-04 Tap(v15) / Gas Range
Frigidaire 76-8667-66-05 Tap(v15) / Gas Range
Frigidaire 76-8667-66-06 Tap(v19) / Gas Range
Frigidaire 76-8667-66-07 Tap(v7) / Gas Range
Frigidaire 76-8667-66-08 Tap(v11) / Gas Range
Frigidaire 76-8966-32-03 Tap(v24) / Gas Range
Frigidaire 76-8967-00-01 Tap(v13) / Gas Range
Frigidaire 76-8967-00-02 Tap(v17) / Gas Range
Frigidaire 76-8967-00-03 Tap(v21) / Gas Range
Frigidaire 76-8967-00-04 Tap(v13) / Gas Range
Frigidaire 76-8967-00-05 Tap(v17) / Gas Range
Frigidaire 76-8967-00-06 Tap(v21) / Gas Range
Frigidaire 76-8967-00-07 Tap(v5) / Gas Range
Frigidaire 76-8967-00-08 Tap(v13) / Gas Range
Frigidaire 76-8967-00-09 Tap(v5) / Gas Range
Frigidaire 76-8967-00-10 Tap(v13) / Gas Range
Frigidaire 76-8967-00-11 Tap(v5) / Gas Range
Frigidaire 76-8967-00-12 Tap(v5) / Gas Range
Frigidaire 76-8967-18-04 Tap(v16) / Gas Range
Frigidaire 76-8967-18-05 Tap(v20) / Gas Range
Frigidaire 76-8967-18-06 Tap(v24) / Gas Range
Frigidaire 76-8967-23-01 Tap(v14) / Gas Range
Frigidaire 76-8967-23-02 Tap(v18) / Gas Range
Frigidaire 76-8967-23-03 Tap(v22) / Gas Range
Frigidaire 76-8967-23-04 Tap(v14) / Gas Range
Frigidaire 76-8967-23-05 Tap(v18) / Gas Range
Frigidaire 76-8967-23-06 Tap(v22) / Gas Range
Frigidaire 76-8967-23-07 Tap(v6) / Gas Range
Frigidaire 76-8967-23-08 Tap(v14) / Gas Range
Frigidaire 76-8967-23-09 Tap(v6) / Gas Range
Frigidaire 76-8967-23-10 Tap(v14) / Gas Range
Frigidaire 76-8967-23-11 Tap(v6) / Gas Range
Frigidaire 76-8967-23-12 Tap(v6) / Gas Range
Frigidaire 76-8967-32-07 Tap(v8) / Gas Range
Frigidaire 76-8967-32-08 Tap(v16) / Gas Range
Frigidaire 76-8967-32-09 Tap(v8) / Gas Range
Frigidaire 76-8967-32-10 Tap(v16) / Gas Range
Frigidaire 76-8967-32-11 Tap(v8) / Gas Range
Frigidaire 76-8967-32-12 Tap(v8) / Gas Range
Frigidaire 76-8967-66-01 Tap(v15) / Gas Range
Frigidaire 76-8967-66-02 Tap(v19) / Gas Range
Frigidaire 76-8967-66-03 Tap(v23) / Gas Range
Frigidaire 76-8967-66-04 Tap(v15) / Gas Range
Frigidaire 76-8967-66-05 Tap(v19) / Gas Range
  #2 (permalink)
Old 05-15-2008, 09:39 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Most likely the problem is a bad bake igniter.
Normally it should take no more than 60 seconds to fire up the burner since the oven thermostat turned "on". If it takes more then the igniter has to be replaced.
- The part number for the oven igniter is AP2150412
Here are the break down diagrams for the Tappan range Model 76-4960-23-04
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Safety Valve ?? tryiturself Oven Repair (including Ranges and Cooktops) 0 05-09-2009 08:52 AM
Safety Valve Problem ? rashaw Oven Repair (including Ranges and Cooktops) 1 05-05-2009 06:37 PM
Safety Valve Assembly weedm Oven Repair (including Ranges and Cooktops) 0 04-02-2009 05:08 PM
safety valve jakenepa Oven Repair (including Ranges and Cooktops) 6 04-18-2008 05:31 PM
safety valve adepinto Oven Repair (including Ranges and Cooktops) 3 02-02-2008 07:08 PM
