After 19 years of good service my thermador microwave went dead !!!
When I move the door latch to the left (microwave position ) :
-The timer dial lights up . -The Micro power dial ligths up . - I hear the timer running noise .
BUT when I push the micro power switch " on " the microwave indicator stays "off , and the microwave doesn't come "on" , doesn't heat up and the fan doesn't come "on" either .
Also , I cannot locate the 2A fuse which I see on the electrical diagram and which I would like to verfy if it is good.
I wonder which component I should test and which critical voltage (s) I should verify to get the power / ligth "on" .
Thank you for any suggestions !
Louis
