| » Oven self clean, circuit path questions |
Model Number: SP28COJ7BG Brand: GE Age: More than 10 years
I'm actually not sure of the age. It is dated with an analog clock.
The tech sheet is no longer with the appliance. And so with it or a wiring diagram I've been unable to determine the path of current. There are many colored wires. Self clean function doesn't work, Broil and Bake do work. The Latching soledoid works and the microswitch and the other switch are working properly too. The "other switch" has contactors and completes common from oven selector to broil element.I'm not sure but self clean indicator light may be in series with it. I ran several voltage readings as well as ohms readings, however I'm going to need a little direction. Ads By Google Related Models |
| Display Modes | |
| No Heat - Least Costly Path To Diagnose and Fix? | DIYDude | Dryer Repair | 7 | 01-24-2010 09:26 AM |
| install circuit board ge oven | arne | Refrigerator & Freezer Repair | 0 | 09-19-2009 10:07 AM |
| Bosch Gas Oven Questions | JohnArrighi | Oven Repair (including Ranges and Cooktops) | 1 | 03-24-2009 06:01 PM |
| oven circuit board trouble | nancyl | Oven Repair (including Ranges and Cooktops) | 1 | 03-24-2009 11:26 AM |
| Thermador oven Display circuit board | Willerm | Oven Repair (including Ranges and Cooktops) | 0 | 07-25-2008 04:20 PM |
