| » Gas oven won't light |
Model Number: PG0191 U Brand: Modern Maid Age: More than 10 years
I have a Modern Maid double oven, the top oven won’t light, the igniter turns red but the gas does not flow, the igniter will turn off after about 10 min. the broiler and bottom oven works fine.
Model Number PG0191U Serial Number 6773460 Igniter by Norton Model Number is 501 No one has this igniter Ads By Google Related Models Last edited by tpon : 05-16-2008 at 04:28 PM. |
I cant seem to pull anything up on the model you listed
please check the model and serial tag on the oven. In most cases the glowbar ignitor itself is responsible for this. It is connected in series with the burnner valve. The ignitor can still operate but at the same time not allow enough current to pass through it to open the burnner valve so that the gas can flow through to the burner. |
| Display Modes | |
| Oven burner wont light or takes a long time to light | shadyray | Oven Repair (including Ranges and Cooktops) | 4 | 01-30-2011 08:26 PM |
| Blinking Blue Lights (Oven ON Light & Oven Heating Light | bubbah2os | Oven Repair (including Ranges and Cooktops) | 1 | 02-05-2010 01:07 PM |
| kenmore oven will light, bring oven to temp, but won't re-light after the temp.... | weedsnager | Oven Repair (including Ranges and Cooktops) | 1 | 12-02-2009 05:28 PM |
| Oven doesn't light, Broil and Preheat will light | tisears | Oven Repair (including Ranges and Cooktops) | 1 | 09-09-2009 12:38 PM |
| magic chef propane oven won't light (has pilot light) | A and J | Oven Repair (including Ranges and Cooktops) | 3 | 09-19-2008 12:36 PM |
