Appliance Repair Forum
-   Oven Repair (including Ranges and Cooktops) (http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/)
-   -   No clicking from one burner (http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/793-no-clicking-one-burner.html)
Joepilot 08-29-2007 09:40 AM
I can turn every other knob and all four igniters will spark. When turning knob for this burner only gas comes on. Which part do I need to replace? The spark module or the actual valve or somethiong else I can not figure out from diagram-Thanks
Admin / APP Team 08-29-2007 02:11 PM
Joe,
Please post the complete model number. You're missing a few letters and numbers on the end. There is a tag on the range that has both the model and serial numbers on it. Post back...
Joepilot 08-29-2007 05:47 PM
JGP932BEC2BB-Thank you
Admin / APP Team 08-29-2007 11:27 PM
Spark module should be fine since all 4 igniters are working. There is a small chance that the module is bad, but most likely the problem is with the igniter switch (located on the valve itself).
GE does not sell these switches individually for your model, it comes as a harness kit with wiring and 4 switches. See #323 on this diagram (and parts list).
Joepilot 08-30-2007 05:36 AM
Thank you very much
rdutrow 02-08-2011 07:41 PM
Part Number GE AP3783914 does not fit
I ordered this part for my JGP932BEC2BB gas cooktop stove and it is completely different than the original OEM part that came with the stove. It does not fit over each burner control, no matter how you turn it. The tag on the new wiring harness says 191D4235P002, but my OEM wiring harness says 191D3135P0002. Does anyone know the correct part to order?
