I am replacing the clock on a Tappan TGF362BBBC stove, and am not sure how to remove the old push buttons from the old clock and don't want to break them...any suggestions how to do this? They are described as a push button type and model # AP2125113...do I have to replace them? There is nothing wrong with the current ones. Thanks!:confused:
John, Very often it is not possible to pull out those buttons without breaking some of them. Try to drop a soapy water along the shaft to lubricate it. If any of them broke, order replacement. The Part number: AP2125113
is the correct part number. Gene.
