Discuss
Oven won't stay on
 in
I have a propane fueled Hardwick stove. The pilot light on the oven lights and the secondary flame for the
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Oven won't stay on
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 05-12-2008, 07:17 AM
Nancy P. Nancy P. is offline
Junior Member
Nancy P. is on a distinguished road
Default Oven won't stay on
Model Number: SB1616W1OR   Brand: Hardwick   Age: More than 10 years
I have a propane fueled Hardwick stove. The pilot light on the oven lights and the secondary flame for the thermo couple lights. Once the thermo couple heats up the oven lights but after about 20 seconds the thermo couple flame goes out and the oven flame gradually goes out. It appears that the gas is being shut off to the oven flame. I made sure the propane tank is full.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 05-13-2008, 11:04 AM
SublimeMasterJW SublimeMasterJW is online now
Senior Expert
APP Volunteer
SublimeMasterJW is on a distinguished road
Default Get a torch and do a test
Hold the torch to the pilot assembly and see if the flame stays on. If it does then repositioning the copper/nickel probe on the pilot light may make it stay lit. For optimum performance the flame needs to hit the very tip of the bulb. The copper/nickel bulb when heated produces electrical current which opens a bi-metal flap inside the gas valve. You may just have to replace that safety valve if that flame will not hold. Some times buildup on the pilot itself will make the flame smaller. Don't try to open the pilot hole but instead try and clean it with a wire brush or some rustbuster.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Gas Oven won't stay lit janicet Oven Repair (including Ranges and Cooktops) 3 03-26-2008 08:54 PM
Oven won't stay lit mikevanhal Oven Repair (including Ranges and Cooktops) 1 02-15-2008 12:41 PM
Oven won't stay on kristina Oven Repair (including Ranges and Cooktops) 2 02-04-2008 11:07 AM
Oven will not stay lit bradk36 Oven Repair (including Ranges and Cooktops) 1 01-15-2008 06:33 PM
Oven won't stay lit donnalee115 Oven Repair (including Ranges and Cooktops) 3 11-27-2007 03:27 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
