Discuss
Thermador igniter replacement
 in
Over time all ignitors (electrodes) on this SS low profile cooktop have popped-out. They seem mechanically sound. Is there
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Thermador igniter replacement
  #1 (permalink)
Old 05-11-2008, 09:17 PM
FrankEnstein FrankEnstein is offline
Junior Member
FrankEnstein is on a distinguished road
Default Thermador igniter replacement
Model Number: SGN30S   Brand: Thermador   Age: 5 - 10 years
Over time all ignitors (electrodes) on this SS low profile cooktop have popped-out. They seem mechanically sound. Is there a method of reinstalling/replacing them from above (special circlip)? If it all needs dismantling are there specific things to watch out for. This seems a rare beast - probably made by Bosch?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 05-13-2008, 08:31 AM
Servicer Servicer is offline
Senior Expert
APP Volunteer
Servicer is on a distinguished road
Default
Hello,
Yes, it sounds like the mounting clips, Thermador number 189322, have deteriorated over time. To replace these you'll need to remove the burner bases which require the 20mm venturi tube to be unscrewed. Once that's out the burner base and plate will be able to be removed. The burner plate is the part the igniter goes through.
One note, be careful if the venturi tube does not want to turn. It screws into a part called a jet-holder assembly. Overtime, these components can freeze together which requires the tube to be drilled out. If you are able to remove them make sure you use some anti-seize grease on the threads to insure it does not freeze up in the future.
KC
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Thermador Help gearhead1218 Oven Repair (including Ranges and Cooktops) 6 04-11-2008 09:21 PM
Help! Range Igniter Replacement LSchm Oven Repair (including Ranges and Cooktops) 1 04-04-2008 06:09 PM
Requesting help with a GE igniter replacement cfbeebe Oven Repair (including Ranges and Cooktops) 2 12-08-2007 11:26 AM
Igniter replacement wrightralph Oven Repair (including Ranges and Cooktops) 1 11-10-2007 12:17 PM
how to replace igniter on thermador gas grill cosomactoo Oven Repair (including Ranges and Cooktops) 1 09-19-2007 08:24 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
