| » gas range oven not heating |
| By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use. |
Model Number: kgra806pss00 Brand: Kitchen Aid Age: 1 - 5 years
my husband replaced the membrane switch and that corrected the problems with the touch pad, but the oven still does not heat. fan starts when bake cycle started but ignitor and gas valve do not operate. The oven light is on all the time and will not shut off even with the new membrane switch. We have not used the self clean feature ever after reading all of the problems. Broiler does not operate either. Oven would work for a while before we replaced the membrane switch, but had to unplug the range to turn it off. Then the oven quit working. My husband thinks the next part to replace is the #9761594 appliance central. I'm hoping it is something cheaper like a fuse. Any help would be greatly appreciated.
thanks, Anmery |
Did you hear a clicking sound when you tried to use Bake or Broil?
__________________
Professional appliance repair services in Orange County, California. |
Remove the control panel back cover and check for 120V between the black wire and the white/red wire on the spark module (wires have to be removed) while the control calls for Bake.
If there is 120V then the problem is a bad spark module. If there is no 120V then the problem is a bad control board. - The part number for the spark module is AP3672576 - The part number for the control board is AP3872569 Gene.
__________________
| Display Modes | |
| Jenn-Air range oven, heating element burnt, clock won't display | wuchinguo | Oven Repair (including Ranges and Cooktops) | 0 | 04-15-2008 08:41 AM |
| Jenn-Air Range, oven not heating | Mark Wise | Oven Repair (including Ranges and Cooktops) | 5 | 02-09-2008 03:49 PM |
| GE Wall Double Oven Top Oven Not Heating | ryoung | Oven Repair (including Ranges and Cooktops) | 0 | 01-10-2008 08:02 PM |
| Frigidaire Electric Range Heating Element Replacement | johnhmon | Oven Repair (including Ranges and Cooktops) | 0 | 10-06-2007 04:14 PM |
| Range top and oven heating | Emily | Oven Repair (including Ranges and Cooktops) | 1 | 09-14-2007 10:07 PM |
