Discuss
Kitchenaid Cooktop
 in
Maybe Gene can help me out. I have an old infinite switch that doesn't match exactly with the new
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Kitchenaid Cooktop
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 05-10-2008, 03:24 PM
kc135guy kc135guy is offline
Junior Member
kc135guy is on a distinguished road
Default Kitchenaid Cooktop
Brand: Kitchen Aid   Age: 5 - 10 years
I have an old infinite switch that doesn't match exactly with the new infinite switch. Pix attached.
I figured out the pink wire (power), the black and violet I already connected, but there are 3 orange that I can't figure out where they go.
If anyone can help out, please call me at 785-478-1286 or 785-220-3940. Or I can call you - no problem.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 05-10-2008, 07:14 PM
misterfixall misterfixall is offline
Senior Expert
APP Volunteer
misterfixall is on a distinguished road
Default
orange with white stripe- h1a . orange with black stripe-h1b, solid orange-h2
__________________
  #3 (permalink)
Old 05-10-2008, 07:29 PM
Junior Member
Default
Thanks for the response. There is a pink wire that goes on as well for a total of 4 wires left. None of the orange wires have a stripe, just different colored lettering. The two with orange and black seem identical.
Also, the top picture was the old one and I think the pink and orange one on the left were in the wrong place.
Chris
  #4 (permalink)
Old 05-10-2008, 07:52 PM
Senior Expert
APP Volunteer
Default
did you take note of the wires and where they were located before you removed them?
__________________
  #5 (permalink)
Old 05-11-2008, 05:53 AM
Junior Member
Default
No - (and I even sat there and thought about taking a picture before I pulled wires) but the 2nd picture (original switch) was my best guess, unfortunately when I tried to turn it on, the breaker blew. So the 2nd picture is incorrect, I am pretty sure the black, violet, and 2 orange black wires were correct. I might have switched the pink and orange/white.
Thanks for helping -
  #6 (permalink)
Old 05-11-2008, 03:47 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Hi Chris,
So far I can tell you that the terminals L1 & L2 are for incoming power, the terminals H1a & H1b are for two coils on the dual heat element and the terminal H2 is for a common terminal on the dual heat element, and the P terminal is for the indicator light.
What is the complete model number of the unit?
What burner this switch is for and what kind of the heat element it has?
Check if there is any marks on the wires and trace all wires. Post which wire where goes.
__________________
Professional appliance repair services in Orange County, California.
  #7 (permalink)
Old 05-11-2008, 06:14 PM
Senior Expert
APP Volunteer
Default
do you have the wiring diagram that came with stove? ,i assume this original switch is different from the rest of the switches oterwise you would have compared them.
__________________
  #8 (permalink)
Old 05-11-2008, 07:08 PM
Junior Member
Default
Gene & Mr Fixall,
The model # is KECC502GBT3, the burner is the LF double burner. The kitchenaid part # was 3188516 which is now the whirlpool 8203534.
I will trace the wires. I can take more pictures also and repost them.
The wires have some markings - one orange has white letters, then two oranges have black letters. Am I looking for something specific on the wires?
Any idea about that pink wire? The two wires that go into the unit are black and pink.
You guys are really helping me out. Needless to say, I have never worked on a cooktop before and have limited knowledge of electrical work.
Concerning the heat element - I don't really understand that question.
Thanks for giving me some insight already.
Chris
  #9 (permalink)
Old 05-11-2008, 07:13 PM
Junior Member
Default
Mr Fixall
We bought the house 5 years ago and there wasn't any paperwork with the appliances. I found some information online, but not a wiring diagram.
The switch is different from the other 3, this was blue the other three were white. When I took the part out, I thought the wires would go exactly the way they came off, but then I saw instruction sheet placed the wires somewhere else on the switch.
  #10 (permalink)
Old 05-12-2008, 05:55 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Chris,
If you can take pictures of this heating element, shown all terminals with wires and post them, it might help. Also try to read all white and black letters on the wires and post it too.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
kitchenaid cooktop gasket mark31904 Oven Repair (including Ranges and Cooktops) 2 04-27-2008 06:03 PM
KitchenAid oven and cooktop mark31904 Oven Repair (including Ranges and Cooktops) 0 04-12-2008 07:01 PM
kitchenaid cooktop won't shut off jappel2 Oven Repair (including Ranges and Cooktops) 1 03-20-2008 06:20 PM
Kitchenaid Stove F2 shuditstayorgo Oven Repair (including Ranges and Cooktops) 1 03-04-2008 03:11 PM
kitchenaid icemaker matthew Refrigerator & Freezer Repair 1 09-02-2007 10:40 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
