Oven will not light. Pilot lights And stays on, however, when thermostat valve nob turned to oven the burner will not light. Should the pilot touch thermocouple initially or when thermostat valve is turned from pilot to oven on. Waiting up to 60 sec. with 0 results. Have a feeling either the pilot or thermostat valve is bad?
