| » Oven door light switch |
| By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use. |
Brand: Tappan Age: More than 10 years
I just receive switch part #AP3851660. I removed existing 51 year old switch with "bakelite" plunger broken off. The switches looked almsot exactly alike. 2 "Blade" connectors. The switch is parelled with a toggle switch on the control panel. Simple in-line switch circuit diagram. Except - when I powered up - The light comes on when I shut the door and goes off when I open it ??? Is this correct part or am I missing something about a simple in-line switch replacement??
What is the model number of the oven? How did you get this part number?
__________________
Professional appliance repair services in Orange County, California. |
It is a 1957 Tappan double wall oven. ALL stainless steel. Model #EOKLVR-31 S/N H 44963.
The circuit diagram has single line from power to a wire nut with 2 wires out - one to door switch and one to toggle switch on panel - then wire nut again with single wire to ground. No sure how I found it but I was in the Stove/Oven category, but it looks exactly like one I took out. I printed web page and it doesn't say there what the switch is for - possible problem. Thanks for your prompt response |
Check the old switch for continuity (using a pin to push the plunger) to find out if it's normally open or normally closed. Do the same test with the new switch and compare.
Post the results. Gene.
__________________
Oven light is on when door is shut so the switch must be normally open and closes when door pushes it in. I verified at appliance store and bought his that worked correctly. Why does the description on web site not define the switch operation??
| Display Modes | |
| Installing Oven Door Switch | hesper73 | Oven Repair (including Ranges and Cooktops) | 0 | 04-18-2008 11:53 AM |
| refrigerator door light switch | consie | Refrigerator & Freezer Repair | 1 | 03-25-2008 10:37 AM |
| My oven door won't stay shut and the light stays on. The door is loose. | Vanise | Oven Repair (including Ranges and Cooktops) | 2 | 03-24-2008 11:36 AM |
| Replace door light switch GE Mongram refrigerator | daespe | Refrigerator & Freezer Repair | 4 | 03-02-2008 02:06 PM |
| replacing oven light switch on frame | kitchenaidguy | Oven Repair (including Ranges and Cooktops) | 0 | 12-15-2007 01:46 PM |
