Discuss
Oven door light switch
 in
I just receive switch part #AP3851660. I removed existing 51 year old switch with "bakelite" plunger broken off.
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Oven door light switch
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 05-10-2008, 08:48 AM
wmmdavis wmmdavis is offline
Junior Member
wmmdavis is on a distinguished road
Default Oven door light switch
Brand: Tappan   Age: More than 10 years
I just receive switch part #AP3851660. I removed existing 51 year old switch with "bakelite" plunger broken off. The switches looked almsot exactly alike. 2 "Blade" connectors. The switch is parelled with a toggle switch on the control panel. Simple in-line switch circuit diagram. Except - when I powered up - The light comes on when I shut the door and goes off when I open it ??? Is this correct part or am I missing something about a simple in-line switch replacement??
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 05-10-2008, 05:55 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
What is the model number of the oven? How did you get this part number?
__________________
Professional appliance repair services in Orange County, California.
  #3 (permalink)
Old 05-12-2008, 09:26 AM
Junior Member
Default
It is a 1957 Tappan double wall oven. ALL stainless steel. Model #EOKLVR-31 S/N H 44963.
The circuit diagram has single line from power to a wire nut with 2 wires out - one to door switch and one to toggle switch on panel - then wire nut again with single wire to ground.
No sure how I found it but I was in the Stove/Oven category, but it looks exactly like one I took out. I printed web page and it doesn't say there what the switch is for - possible problem. Thanks for your prompt response
  #4 (permalink)
Old 05-12-2008, 10:31 AM
Junior Member
Default
I sent AP # but invoice has another #-(316445500)
  #5 (permalink)
Old 05-13-2008, 09:11 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Check the old switch for continuity (using a pin to push the plunger) to find out if it's normally open or normally closed. Do the same test with the new switch and compare.
Post the results.
__________________
  #6 (permalink)
Old 05-15-2008, 10:11 AM
Junior Member
Default
Oven light is on when door is shut so the switch must be normally open and closes when door pushes it in. I verified at appliance store and bought his that worked correctly. Why does the description on web site not define the switch operation??
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Installing Oven Door Switch hesper73 Oven Repair (including Ranges and Cooktops) 0 04-18-2008 11:53 AM
refrigerator door light switch consie Refrigerator & Freezer Repair 1 03-25-2008 10:37 AM
My oven door won't stay shut and the light stays on. The door is loose. Vanise Oven Repair (including Ranges and Cooktops) 2 03-24-2008 11:36 AM
Replace door light switch GE Mongram refrigerator daespe Refrigerator & Freezer Repair 4 03-02-2008 02:06 PM
replacing oven light switch on frame kitchenaidguy Oven Repair (including Ranges and Cooktops) 0 12-15-2007 01:46 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
