| » Maytag stove burner not lighting |
Model Number: PGR4310CDW Brand: Maytag Age: 5 - 10 years
Hello, my stove top burners will no longer light. The electronic ignition pilot does not click. Both sides. I noticed it was not clicking some times, but would finally light. Now nothing happens. I have to use a lighter to light the stove top burners. I did notice the left side ignightor looks a little burnt. Would one side being bad cause both sides not to work? If i do have to replace the ignitor do I have to pull the range away from the wall? I did try to turn the oven on and it came on after a coupld of miniutes. THANKS for any replies
If it does not click whichever burner is turned On, then the problem most likely is a bad spark module (#4 on the diagram).
- The spark module Part number: AP4094158 Quote:
- The oven igniter Part number: AP4012072 Here is the Service manual. Here are the breakdown diagrams and Replacement parts for MAYTAG PGR4310CDW Range - F/s Std Gas | AppliancePartsPros.com Gene.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
Thanks Gene for the information and manual. Is it possible to replace the spart module without disconnecting the gas and pulling the stove out. Per the manual the spark module is on the left side of the stove and the side panel has to come off. Page 45 of the manusl. Please let me know if it is possible to replace the spark module without pulling the stove out from the wall. Thanks J.S
You have to follow the instructions from the Service manual. If it says the range has to be pulled out, then you have to pull it out. It is not necessarily to disconnect the gas line if it's long enough.
__________________
The new one is bigger and there is no way to mount it in the original position. Also I have no way of knowing where the connections go. I see there are 2 power connections and 2 connections that go to the spark assy. Do you know how I can find out what to do here. THANKS Update Gene I found this part on your website Part Details - WHIRLPOOL Spark module kit, part number: AP4010034 This is what mine looks like. I checked the model # 2x and I did have the correct stove model #, however the part you referred me to and the one that is on the web site does not match. What do you recommend? Last edited by jbstx : 05-24-2010 at 10:45 AM. Reason: ATTACHING PHOTO |
The spark module with the part number AP4094158 comes up as a search result by your model number. All these diagrams came from the manufacturer and I do not know why they used this part. It is possible to install it instead of the original, but it needs some alterations.
The spark module you found looks almost exactly as the original and you definitely can use it. Contact the Appliance Parts Pros customer service and they will exchange the part. Gene.
__________________
| Display Modes | |
| Thermador XLO Burner Not Lighting | d110pickup | Oven Repair (including Ranges and Cooktops) | 1 | 06-24-2009 07:27 AM |
| Bake Burner not lighting. | Necromancer | Oven Repair (including Ranges and Cooktops) | 2 | 04-30-2009 01:25 PM |
| My oven burner not lighting | jbee51 | Oven Repair (including Ranges and Cooktops) | 0 | 04-01-2009 03:59 PM |
| Burner clicking but not lighting | repairnewbie | Oven Repair (including Ranges and Cooktops) | 3 | 08-19-2008 01:28 PM |
| Stove top lighting troubles | wksmith | Microwave Repair | 1 | 05-29-2008 03:36 PM |
