Discuss
Ceramic block assy for element
 in
I ordered item 52 and item 54 from your web site http://www.appliancepartspros.com/partsearch/model.aspx?model_id=217210 based partly from the Diagram Location in the
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Ceramic block assy for element
  #1 (permalink)
Old 02-11-2010, 03:17 PM
Junior Member
jhungerf is on a distinguished road
Default Ceramic block assy for element
Model Number: JXDC430R2BL   Brand: GE   Age: 1 - 5 years
I ordered item 52 and item 54 from your web site http://www.appliancepartspros.com/partsearch/model.aspx?model_id=217210 based partly from the Diagram Location in the top as identifiers and then from the pictures that were available from the Parts break down description look up beneath. Item 52 was received as pictured from the Part Description beneath. I ordered item 54 because item 52 didn't show any wires or contacts with it. The wires that are coming from the contacts of 52 go directly to item 55. That is why I ordered item 54 which is not pictured. What I received was a green wire with two eyelets on the ends instead of one eyelet and one spade type connector that the element would slide into. I would like to use the ceramic block and need the contact that will slide into it with a wire attached that can have the screw attach it to the male terminal item 55.
Jim Hungerford
Ads By Google
Related Models
General Electric JXDC430R2BL Electric range
General Electric JXDC440R2WH Electric range
General Electric JXDD43001 Electric range
General Electric JXDD430N1 Electric range
General Electric JXDD44 Electric range
General Electric JXDD46101 Electric range
General Electric JXDD461N1 Electric range
General Electric JXDL44001 Electric range
General Electric JXDL440K1 Electric range
General Electric JXDL440N1 Electric range
General Electric JXDL45101 Electric range
General Electric JXDL451N1 Electric range
General Electric JXDL47001 Electric range
General Electric JXDL470N1 Electric range
General Electric JXDL491N1 Electric range
General Electric JXDM2 Electric range
General Electric JXDR47 Electric range
General Electric JXDR48 Electric range
General Electric JXDR49 Electric range
General Electric JXDR50 Electric range
General Electric JXDR50V1B RADIANT MODULE
General Electric JXDR50V1C RADIANT MODULE
General Electric JXDR50V1W RADIANT MODULE
Maytag JXDR7301VS0 30" AND 36" RETRACTABLE DOWN DRAFT VENT SYSTEM
Maytag JXDR7301VS1 30" AND 36" RETRACTABLE DOWN DRAFT VENT SYSTEM
Maytag JXDR7361VS0 30" AND 36" RETRACTABLE DOWN DRAFT VENT SYSTEM
Maytag JXDR7361VS1 30" AND 36" RETRACTABLE DOWN DRAFT VENT SYSTEM
General Electric JXDS42001
General Electric JXDS42001BC Electric range
General Electric JXDS420K1 Electric range
General Electric JXDS420N1 Electric range
General Electric JXDS430R1BL Electric range
General Electric JXDS440R1WH Electric range
General Electric JXDS48 ELECTRIC RANGE
General Electric JXDS48101 Electric range
General Electric JXDS481N1 Electric range
General Electric JXDV6601 Electric range
General Electric JXDV69001 Electric range
General Electric JXDV69901 Electric range
General Electric JXGB89B Range accessory
General Electric JXGB89W Range accessory
General Electric JXGC5101 Electric range
General Electric JXGC51T01BB Electric range
General Electric JXGC52T01WW Electric range
General Electric JXGC89B Range accessory
General Electric JXGC89W Range accessory
General Electric JXGD5901 Electric range
General Electric JXGG89 Range accessory
General Electric JXGL5701 Electric range
General Electric JXGL5801 Electric range
General Electric JXGL89 Range accessory
General Electric JXGM201 Electric range
General Electric JXGR6101 Electric range
General Electric JXGR6102 Electric range
General Electric JXGR6103 Electric range
General Electric JXGR6104 Electric range
General Electric JXGR61T01BB Electric range
General Electric JXGR62T01WW Electric range
General Electric JXGS5401 Electric range
Maytag JXI5036WS 36" & 42" PROFESSIONAL HOOD
Maytag JXI5036WS0 36" & 42" PROFESSIONAL HOOD
Maytag JXI5042WS 36" & 42" PROFESSIONAL HOOD
Maytag JXI5042WS0 36" & 42" PROFESSIONAL HOOD
Maytag JXI8036WS0 36" & 42" PROFESSIONAL HOOD
Maytag JXI8042WS0 36" & 42" PROFESSIONAL HOOD
Maytag JXI8236WS 36" & 42" PROFESSIONAL HOOD
Maytag JXI8236WS0 36" & 42" PROFESSIONAL HOOD
Maytag JXI8242WS 36" & 42" PROFESSIONAL HOOD
Maytag JXI8242WS0 36" & 42" PROFESSIONAL HOOD
Maytag JXP5032WS 32" PROFESSIONAL HOOD
Jenn-Air JXP5032WS0 32" PROFESSIONAL HOOD
Maytag JXP5032WW 32" PROFESSIONAL HOOD
Jenn-Air JXP5032WW0 32" PROFESSIONAL HOOD
General Electric JXS2801 Electric range
General Electric JXS3001 Electric range
General Electric JXS3101 Electric range
General Electric JXS3201 Electric range
General Electric JXS3301 Electric range
General Electric JXS3401 Electric range
General Electric JXS4001 Electric range
General Electric JXS5201BB Electric range
General Electric JXS5301WW Electric range
General Electric JXS5401AA Electric range
General Electric JXS6201BB Electric range
General Electric JXS6301WW Electric range
General Electric JXS6401AA Electric range
Jenn-Air JXT5830ADB HOOD
Jenn-Air JXT5830ADS HOOD
Jenn-Air JXT5830ADW HOOD
Jenn-Air JXT5836ADB HOOD
Jenn-Air JXT5836ADS HOOD
Jenn-Air JXT5836ADW HOOD
Maytag JXT6030ADR0 30/36" Range Hood (Vented)
Maytag JXT6036ADR0 30/36" Range Hood (Vented)
Jenn-Air JXT7036ADS HOOD
Jenn-Air JXT8030ADS HOOD
Jenn-Air JXT8036ADS HOOD
Jenn-Air JXT8042ADS HOOD
Jenn-Air JXT8136ADS HOOD
Jenn-Air JXT8142ADS HOOD
Jenn-Air JXT8836ADS HOOD
Jenn-Air JXT9024AAP HOOD
Jenn-Air JXT9027AAP HOOD
Jenn-Air JXT9030ADP HOOD
Jenn-Air JXT9030BDP HOOD
Jenn-Air JXT9030CDP HOOD
Jenn-Air JXT9036ADP HOOD
Jenn-Air JXT9036BDP HOOD
Jenn-Air JXT9036CDP HOOD
Jenn-Air JXT9048ADP HOOD
Jenn-Air JXT9048BDP HOOD
Jenn-Air JXT9048CDP HOOD
Jenn-Air JXT9130CDP HOOD
Jenn-Air JXT9136CDP HOOD
Maytag JXU9130WP0 (30")(36") Professional Hood
Maytag JXU9136WP0 (30")(36") Professional Hood
Maytag JXW5030WS 30" & 36" PROFESSIONAL HOOD
Maytag JXW5030WS0 30" & 36" PROFESSIONAL HOOD
Maytag JXW5036WS 30" & 36" PROFESSIONAL HOOD
Maytag JXW5036WS0 30" & 36" PROFESSIONAL HOOD
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Ceramic Top Element Troubleshoot Chramy Oven Repair (including Ranges and Cooktops) 1 11-19-2008 09:33 AM
Surface element block rewiring teresa1 Oven Repair (including Ranges and Cooktops) 1 10-28-2008 12:22 PM
Replacing element of Maytag Ceramic Top Slide In Range kaliqcda Oven Repair (including Ranges and Cooktops) 0 10-22-2008 05:29 PM
element burned out in ceramic top oven Deb26 Oven Repair (including Ranges and Cooktops) 1 08-17-2008 07:24 PM
Ceramic top heating element does not work stadepal Oven Repair (including Ranges and Cooktops) 0 06-14-2008 06:45 PM
