Discuss
surface switch for GE Oven
 in
The suface light switch, part # WB24X0099 is no longer available. I would like to remove the switch and search
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » surface switch for GE Oven
  #1 (permalink)
Old 05-06-2008, 10:23 AM
Junior Member
lauerbac@suffolk.lib.ny.u is on a distinguished road
Default surface switch for GE Oven
Model Number: JHP67GV4   Brand: GE   Age: More than 10 years
The suface light switch, part # WB24X0099 is no longer available. I would like to remove the switch and search an electornic store to replace it.
How do I remove the panel that houses the switch, (as well as numerous dials and the clock).
Thank you...Lee
Ads By Google
Related Models
General Electric JHP68G*01 Hi-low range
General Electric JHP68G*02 Hi-low range
General Electric JHP69G*H2 Hi-low range
General Electric JHP69G*J1 Hi-low range
General Electric JHP69G*K1 Hi-low range
General Electric JHP69G*K2 Hi-low range
General Electric JHP69G*K3 Hi-low range
General Electric JHP69G*K4 Hi-low range
General Electric JHP69G*K5 Hi-low range
General Electric JHP69GN1 Hi-low range
General Electric JHP69GN2 Hi-low range
General Electric JHP69GN3AD Electric range
General Electric JHP69GN3WH Electric range
General Electric JHP69GN4AD Electric range
General Electric JHP69GN4WH Electric range
General Electric JHP70G*M1 Hi-low range
General Electric JHP70GN1 Hi-low range
General Electric JHP70GN2 Hi-low range
General Electric JHP70GN3AD Electric range
General Electric JHP70GN3WH Electric range
General Electric JHP70GN4AD Electric range
General Electric JHP70GN4WH Electric range
General Electric JHP70GN5AD Electric range
General Electric JHP70GN5WH Electric range
General Electric JHP70N*K1 Hi-low range
General Electric JHP70N*K2 Hi-low range
General Electric JHP70N*K3 Hi-low range
General Electric JHP70N*K4 Hi-low range
General Electric JHP70N*K5 Hi-low range
General Electric JHP70V*K1 Hi-low range
General Electric JHP70V*K2 Hi-low range
General Electric JHP70V*K3 Hi-low range
General Electric JHP70V*K4 Hi-low range
General Electric JHP70V*K5 Hi-low range
General Electric JHP75G*01 Hi-low range
General Electric JHP75G*02 Hi-low range
General Electric JHP75G*03 Hi-low range
General Electric JHP75G*D1 Hi-low range
Maytag JHP848 Commercial Cooking
General Electric JHP97G*D1 Hi-low range
General Electric JHP97G*Y2 Hi-low range
General Electric JHP97G*Y3 Hi-low range
General Electric JHP97G*Y5 Hi-low range
General Electric JHP97G*Y6 Hi-low range
General Electric JHP98G*Y2 Hi-low range
General Electric JHP98G*Y3 Hi-low range
General Electric JHP98G*Y4 Hi-low range
General Electric JHP98G*Y5 Hi-low range
Maytag JHPE2218 Commercial Cooking
Maytag JHPE2224 Commercial Cooking
Maytag JHPE3324 Commercial Cooking
Maytag JHPE3336 Commercial Cooking
Maytag JHPE4336 Commercial Cooking
Whirlpool JHWS160ACR4
Whirlpool JHWS160AWH4
General Electric JIC100H1 Electric range
Jenn-Air JIM1550ACX Undercounter Built in Ice Maker
Jenn-Air JIM1550ARB Undercounter Built in Ice Maker
Jenn-Air JIM1550ARS Undercounter Built in Ice Maker
Jenn-Air JIM1550ARW Undercounter Built in Ice Maker
Maytag JIM158XBCX0 Ice Cube Maker
Maytag JIM158XBCX1 Ice Cube Maker
Whirlpool JIM158XBRB0 Ice Cube Maker
Maytag JIM158XBRB0 Ice Cube Maker
Maytag JIM158XBRB1 Ice Cube Maker
Whirlpool JIM158XBRS0 Ice Cube Maker
Maytag JIM158XBRS0 Ice Cube Maker
Maytag JIM158XBRS1 Ice Cube Maker
Whirlpool JJEC5100XT0
Whirlpool JJTF8500XLP1
Whirlpool JJTF8500XLP2
Whirlpool JJTF8500XLP3
Whirlpool JJTF8500XLP4
Whirlpool JJTF8500XLP5
Whirlpool JJTU4100XTP0
Whirlpool JJTU4100XTP1
Whirlpool JJTU4600XTP0
Whirlpool JJTU4600XTP1
Whirlpool JJTU8100XTP0
Whirlpool JJTU8100XTP1
Jenn-Air JJW7530DDB Convenience Walloven - S/c Elec
Jenn-Air JJW7530DDS Convenience Walloven - S/c Elec
Jenn-Air JJW7530DDW Convenience Walloven - S/c Elec
Jenn-Air JJW8127AAB Walloven - S/c Ele
Jenn-Air JJW8127AAW Walloven - S/c Ele
Jenn-Air JJW8130AAB Walloven - S/c Ele
Jenn-Air JJW8130AAW Walloven - S/c Ele
Jenn-Air JJW8130DDB Walloven - S/c Ele
Jenn-Air JJW8130DDS Walloven - S/c Ele
Jenn-Air JJW8130DDW Walloven - S/c Ele
Jenn-Air JJW8227AAB Walloven - S/c Ele
Jenn-Air JJW8227AAW Walloven - S/c Ele
Jenn-Air JJW8230AAB Walloven - S/c Ele
Jenn-Air JJW8230AAW Walloven - S/c Ele
Jenn-Air JJW8230DDB Walloven - S/c Ele
Jenn-Air JJW8230DDS Walloven - S/c Ele
Jenn-Air JJW8230DDW Walloven - S/c Ele
Jenn-Air JJW8527AAB Walloven - S/c Ele
Jenn-Air JJW8527AAW Walloven - S/c Ele
Jenn-Air JJW8527BAB Walloven - S/c Ele
Jenn-Air JJW8527BAW Walloven - S/c Ele
Jenn-Air JJW8527CAB Walloven - S/c Ele
Jenn-Air JJW8527CAS Walloven - S/c Ele
Jenn-Air JJW8527CAW Walloven - S/c Ele
Jenn-Air JJW8527DDB Walloven - S/c Ele
Jenn-Air JJW8527DDQ Walloven - S/c Ele
Jenn-Air JJW8527DDS Walloven - S/c Ele
Jenn-Air JJW8527DDW Walloven - S/c Ele
Jenn-Air JJW8530AAB Walloven - S/c Ele
Jenn-Air JJW8530AAW Walloven - S/c Ele
Jenn-Air JJW8530ACB Walloven - S/c Ele
Jenn-Air JJW8530ACW Walloven - S/c Ele
Jenn-Air JJW8530BAB Walloven - S/c Ele
Jenn-Air JJW8530BAW Walloven - S/c Ele
Jenn-Air JJW8530BCB Walloven - S/c Ele
Jenn-Air JJW8530BCW Walloven - S/c Ele
Jenn-Air JJW8530CAB Walloven - S/c Ele
Jenn-Air JJW8530CAS Walloven - S/c Ele
Jenn-Air JJW8530CAW Walloven - S/c Ele
Jenn-Air JJW8530CCB Walloven - S/c Ele
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Frigidaire - Changing Dual Surface Switch mrsdrjones Oven Repair (including Ranges and Cooktops) 55 02-21-2011 03:03 PM
Oven lock switch on Jenn-Air electric oven miriamgreen Oven Repair (including Ranges and Cooktops) 0 10-21-2009 01:40 PM
how to replace surface element on glass top oven douglo Oven Repair (including Ranges and Cooktops) 0 12-20-2008 11:01 AM
Oven comes on with switch off ram04 Oven Repair (including Ranges and Cooktops) 5 08-12-2008 03:37 PM
Maytag Gas Oven.....Surface Burners ALL Ignite..... Tony D. Oven Repair (including Ranges and Cooktops) 6 12-21-2007 10:08 AM
