| » Oven does not heat |
In order to provide most accurate advise we need the complete model number of the range.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
Remove the Bake heating element as far as the wires go and check for a burned wires.
Remove one of the wires and check the heating element for continuity. Replace the Bake heating element if it's open. If there is nothing wrong then replace the control board. - The part number for the Bake heating element is AP3856342 - The part number for the control board is AP3760738 Gene.
__________________
| Display Modes | |
| Wall oven will not heat/re-heat properly | dottavio | Oven Repair (including Ranges and Cooktops) | 0 | 01-07-2010 09:47 AM |
| Oven/clock Control Panel is no longer lit but oven does heat. | jthomas@abrakadoodle.com | Oven Repair (including Ranges and Cooktops) | 1 | 12-05-2009 04:07 PM |
| Oven broiler and burners work - oven will not heat | fatbuford | Oven Repair (including Ranges and Cooktops) | 0 | 11-27-2009 05:50 AM |
| Caloric double oven/bottom oven doesn't heat | kj0505 | Oven Repair (including Ranges and Cooktops) | 1 | 12-10-2008 09:14 AM |
| Bosch 27" Dbl oven Powering on but no heat either oven | badace | Oven Repair (including Ranges and Cooktops) | 0 | 12-02-2007 09:56 AM |
