Discuss
GE range ,oven not working in any mode
 in
I have a GE model no. JBP90A S1AA. Touchpad working ok. No fault codes. Sensor measures 1094 ohms, no short
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » GE range ,oven not working in any mode
  #1 (permalink)
Old 05-05-2008, 01:22 PM
Junior Member
jgk2 is on a distinguished road
Default GE range ,oven not working in any mode
Brand: -brand-   Age: Less than 1 year
I have a GE model no. JBP90A S1AA. Touchpad working ok. No fault codes. Sensor measures 1094 ohms, no short to ground. Door switch checks ok. All 3 elements check ok.Transformer voltages ok. Turn oven on in any mode, set temp. and appropriate relay energizes and sends 240 v. to appropriate element which starts to heat up, but relay only stays energized for a few seconds and then de-energizes. Shortly thereafter oven temp etc. disappears from display. Seems all that is left is the ERC. Anybody have any input?
Thanks, Greg
Ads By Google
  #2 (permalink)
Old 05-05-2008, 06:26 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Greg,
Most likely the problem is a bad electronic control. You have to call Appliance Parts Pros customer service (877-477-7278) for the right part number.
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Range top not working, oven OK sc8194 Oven Repair (including Ranges and Cooktops) 0 01-24-2010 10:23 AM
Range Oven NOT Working johnmou Oven Repair (including Ranges and Cooktops) 1 09-29-2009 06:11 PM
range oven not working aldret Oven Repair (including Ranges and Cooktops) 3 11-18-2008 06:14 PM
Oven not working, range does DavidDavid Oven Repair (including Ranges and Cooktops) 1 07-18-2008 09:04 PM
Range oven NOT working johnmou Oven Repair (including Ranges and Cooktops) 3 07-18-2008 06:25 PM
