Discuss
range kenmore
 in
how i can test a range control board to be sure thats it's damage i got and code that's said
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » range kenmore
  #1 (permalink)
Old 02-09-2010, 11:27 AM
Junior Member
crosuni is on a distinguished road
Question range kenmore
Brand: Kenmore   Age: 1 - 5 years
how i can test a range control board to be sure thats it's damage i got and code that's said pf 5ab
Ads By Google
  #2 (permalink)
Old 02-09-2010, 03:13 PM
Senior Expert
APP Volunteer
denman is just really nice
Default
A model number may help others help you
__________________
  #3 (permalink)
Old 02-10-2010, 04:49 AM
Junior Member
Question kenmore range
model # 66595152300 i try that and still doing the same THING code pf 5a6 E6 what i didn't do was unpluged the unit and left them for a 30 minutes i gonna try that, can i turn off the braker let me know thanks
  #4 (permalink)
Old 02-10-2010, 08:01 AM
Senior Expert
APP Volunteer
Default
Here is the tech sheet.
http://www.servicematters.com/docs/w...%204454088.pdf
pf is usually power failure.
If "PF" appears at any other time, a power failure occurred. To
remove "PF" and to reset the clock, press STOP/CLEAR.
Unplug the unit for half an hour or so to see if it will reset.
If not try to get into the diagnostics so you can see if there is a stored
error code
__________________
  #5 (permalink)
Old 02-15-2010, 01:19 PM
Junior Member
Question Kenmore Range
They Still Doing The Same After I Do All # 66595152300 Let Me Know If I Can Do Anything Else
  #6 (permalink)
Old 02-15-2010, 09:34 PM
Senior Expert
APP Volunteer
Default
It does sound like the control board is toast since you cannot reset the error.
You may want to try the following just in case the keypad is not entering the reset keystrokes but this is a long shot.
Connector Cleaning / Checking
Unplug the unit
Open it up
Remove the ribbon cable from the keypad to the control board at the control board.
Clean the edge connector.
If it is the type where there is not a connector just the insulation is removed, it can be cleaned with a pencil eraser. Do not use an ink eraser as it is too abrasive.
Check the tracks in the ribbon cable for hairline cracks. A magnifying glass helps here.
Would not hurt to clean the connector on the board. Use electronics contact cleaner or isopropyl alcohol and a tooth brush. Be gentle and do not reconnect till all the solvent evaporates.
Reconnect everything and give it a try.
I did look up the board at the Sears parts site 8524212, they want $297.32.
When I cross reference it to the AppliancePartsPros site they want $124.13.
__________________
  #7 (permalink)
Old 02-16-2010, 04:19 AM
Junior Member
Smile kenmore range
thank you i gonna try that have a nice day
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore Gas Range wmichalk Oven Repair (including Ranges and Cooktops) 1 12-29-2009 12:39 PM
Kenmore Gas Range terria Oven Repair (including Ranges and Cooktops) 0 08-12-2009 02:05 PM
kenmore range aquilia Oven Repair (including Ranges and Cooktops) 0 02-27-2009 09:03 AM
kenmore gas range schwallie Oven Repair (including Ranges and Cooktops) 0 01-15-2009 03:32 PM
Kenmore Range - Dim Display Smithwell Oven Repair (including Ranges and Cooktops) 0 10-30-2007 12:19 PM
