Discuss
Oven will not heat
 in
The other day the broiler on a Thermador electric oven got left on with the door closed. Next thing I
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Oven will not heat
  #1 (permalink)
Old 02-08-2010, 05:31 PM
Junior Member
Don in Vegas is on a distinguished road
Default Oven will not heat
Brand: Thermador   Age: 1 - 5 years
The other day the broiler on a Thermador electric oven got left on with the door closed. Next thing I know the oven was beeping non-stop and non of the pressure sensitive button controls would function. I called the company and they told me to trip the circuit breaker, leave it off for 5 minutes and try again. Now the controls work, but when I turn on the oven, only the fan runs and it does not heat up. What's the likely problem and can I order parts and repair it myself?
Ads By Google
  #2 (permalink)
Old 02-08-2010, 09:06 PM
Senior Expert
APP Volunteer
denman is just really nice
Default
A model number may help others help you.
Many units have a hi-limit thermostat in line with the elements, perhaps it is open.
__________________
  #3 (permalink)
Old 02-09-2010, 12:28 PM
Junior Member
Default
It's one of the following SC303, SC301 or SC272. If it has a hi-limit thermostat, can it be reset?
  #4 (permalink)
Old 02-09-2010, 02:10 PM
Senior Expert
APP Volunteer
Default
So I looked up SC301 see below
Replacement parts for THERMADOR SC301T | AppliancePartsPros.com
I could not find any tech info on the unit but looking through the parts.
In Section 3 there is a fuse Item 18 but this is probably for the fan.
In Section 3 there is a thermostat Item 20
In Section 4 there is a thermostat Item 12
Looks like the thermostat's are resettable
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Wall oven will not heat/re-heat properly dottavio Oven Repair (including Ranges and Cooktops) 0 01-07-2010 09:47 AM
Oven/clock Control Panel is no longer lit but oven does heat. jthomas@abrakadoodle.com Oven Repair (including Ranges and Cooktops) 1 12-05-2009 04:07 PM
Oven broiler and burners work - oven will not heat fatbuford Oven Repair (including Ranges and Cooktops) 0 11-27-2009 05:50 AM
Caloric double oven/bottom oven doesn't heat kj0505 Oven Repair (including Ranges and Cooktops) 1 12-10-2008 09:14 AM
Bosch 27" Dbl oven Powering on but no heat either oven badace Oven Repair (including Ranges and Cooktops) 0 12-02-2007 09:56 AM
