Discuss
Whirlpooel electric oven not reaching set temp
 in
Our Whirlpool double electric oven beeps like it has reached the set pre-heat temperature (say 350F) but will be 25-50F
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Whirlpooel electric oven not reaching set temp
  #1 (permalink)
Old 02-08-2010, 10:35 AM
Junior Member
Tracy Winkler is on a distinguished road
Question Whirlpooel electric oven not reaching set temp
Model Number: RBD275PDQ11   Brand: Whirlpool   Age: 5 - 10 years
Our Whirlpool double electric oven beeps like it has reached the set pre-heat temperature (say 350F) but will be 25-50F less than it according to a portable oven thermometer. I then raise manually raise the set point to 365F or so to get it to kick on and reach the right temperature. Is the controller the problem or the sensor? Thanks for feedback....
Ads By Google
Related Models
Whirlpool RBD275PDQ11
Whirlpool RBD275PDQ12
Whirlpool RBD275PDQ13
Whirlpool RBD275PDQ14 27" Built - in Electric Double Oven Std - Clean Lower Self - Clean Upper
Whirlpool RBD275PDQ15 27" Built - in Electric Double Oven Std - Clean Lower Self - Clean Upper
Whirlpool RBD275PDQ2
Whirlpool RBD275PDQ3
Whirlpool RBD275PDQ4
Whirlpool RBD275PDQ6
Whirlpool RBD275PDQ7
Whirlpool RBD275PDQ8
Whirlpool RBD275PDQ9
Whirlpool RBD275PDS12
Whirlpool RBD275PDS14 27" Built - in Electric Double Oven Std - Clean Lower Self - Clean Upper
Whirlpool RBD275PDS15 27" Built - in Electric Double Oven Std - Clean Lower Self - Clean Upper
Whirlpool RBD275PDT10
Whirlpool RBD275PDT11
Whirlpool RBD275PDT12
Whirlpool RBD275PDT13
Whirlpool RBD275PDT14 27" Built - in Electric Double Oven Std - Clean Lower Self - Clean Upper
Whirlpool RBD275PDT15 27" Built - in Electric Double Oven Std - Clean Lower Self - Clean Upper
Whirlpool RBD275PDT8
Whirlpool RBD275PDT9
Whirlpool RBD275PRB00 24" Built - in Electric Double Oven Std - Clean Lower Self - Clean Upper
Whirlpool RBD275PRQ00 24" Built - in Electric Double Oven Std - Clean Lower Self - Clean Upper
Whirlpool RBD275PRS00 24" Built - in Electric Double Oven Std - Clean Lower Self - Clean Upper
Whirlpool RBD275PRS01 27" Built - in Electric Double Oven Convection - Upper Self - Clean (gold Line)
Whirlpool RBD275PRT00 24" Built - in Electric Double Oven Std - Clean Lower Self - Clean Upper
Whirlpool RBD276PDB1
Whirlpool RBD276PDB10
Whirlpool RBD276PDB11
Whirlpool RBD276PDB12
Whirlpool RBD276PDB2
Whirlpool RBD276PDB4
Whirlpool RBD276PDB6
Whirlpool RBD276PDB7
Whirlpool RBD276PDB8
Whirlpool RBD276PDB9
Whirlpool RBD276PDQ1
Whirlpool RBD276PDQ10
Whirlpool RBD276PDQ11
Whirlpool RBD276PDQ12
Whirlpool RBD276PDQ2
Whirlpool RBD276PDQ4
Whirlpool RBD276PDQ6
Whirlpool RBD276PDQ7
Whirlpool RBD276PDQ8
Whirlpool RBD276PDQ9
Whirlpool RBD277PDB1
Whirlpool RBD277PDB2
Whirlpool RBD277PDB4
Whirlpool RBD277PDQ1
Whirlpool RBD277PDQ2
Whirlpool RBD277PDQ4
Whirlpool RBD305PDB1
Whirlpool RBD305PDB10
Whirlpool RBD305PDB11
Whirlpool RBD305PDB12
Whirlpool RBD305PDB13
Whirlpool RBD305PDB14 30" Built - in Electric Double Oven Std - Clean Lower Self - Clean Upper
Whirlpool RBD305PDB15 30" Built - in Electric Double Oven Std - Clean Lower Self - Clean Upper
Whirlpool RBD305PDB2
Whirlpool RBD305PDB3
Whirlpool RBD305PDB4
Whirlpool RBD305PDB6
Whirlpool RBD305PDB7
Whirlpool RBD305PDB8
Whirlpool RBD305PDB9
Whirlpool RBD305PDQ1
Whirlpool RBD305PDQ10
Whirlpool RBD305PDQ11
Whirlpool RBD305PDQ12
Whirlpool RBD305PDQ13
Whirlpool RBD305PDQ14 30" Built - in Electric Double Oven Std - Clean Lower Self - Clean Upper
Whirlpool RBD305PDQ15 30" Built - in Electric Double Oven Std - Clean Lower Self - Clean Upper
Whirlpool RBD305PDQ2
Whirlpool RBD305PDQ3
Whirlpool RBD305PDQ4
Whirlpool RBD305PDQ6
Whirlpool RBD305PDQ7
Whirlpool RBD305PDQ8
Whirlpool RBD305PDQ9
Whirlpool RBD305PDS12
Whirlpool RBD305PDS14 30" Built - in Electric Double Oven Std - Clean Lower Self - Clean Upper
Whirlpool RBD305PDS15 30" Built - in Electric Double Oven Std - Clean Lower Self - Clean Upper
Whirlpool RBD305PDT11
Whirlpool RBD305PDT12
Whirlpool RBD305PDT13
Whirlpool RBD305PDT14 30" Built - in Electric Double Oven Std - Clean Lower Self - Clean Upper
Whirlpool RBD305PDT15 30" Built - in Electric Double Oven Std - Clean Lower Self - Clean Upper
Whirlpool RBD305PRB00 24" Built - in Electric Double Oven Std - Clean Lower Self - Clean Upper
Whirlpool RBD305PRQ00 24" Built - in Electric Double Oven Std - Clean Lower Self - Clean Upper
Whirlpool RBD305PRS00 24" Built - in Electric Double Oven Std - Clean Lower Self - Clean Upper
Whirlpool RBD305PRT00 24" Built - in Electric Double Oven Std - Clean Lower Self - Clean Upper
Whirlpool RBD306PDB1
Whirlpool RBD306PDB10
Whirlpool RBD306PDB11
Whirlpool RBD306PDB12
Whirlpool RBD306PDB13
Whirlpool RBD306PDB14 30" Built - in Electric Double Oven Self - Clean Upper and Lower Ovens
Whirlpool RBD306PDB15 30" Built - in Electric Double Oven Self - Clean Upper and Lower Ovens
Whirlpool RBD306PDB2
Whirlpool RBD306PDB4
Whirlpool RBD306PDB6
Whirlpool RBD306PDB7
Whirlpool RBD306PDB8
Whirlpool RBD306PDB9
Whirlpool RBD306PDQ1
Whirlpool RBD306PDQ10
Whirlpool RBD306PDQ11
Whirlpool RBD306PDQ12
Whirlpool RBD306PDQ13
Whirlpool RBD306PDQ14 30" Built - in Electric Double Oven Self - Clean Upper and Lower Ovens
Whirlpool RBD306PDQ15 30" Built - in Electric Double Oven Self - Clean Upper and Lower Ovens
Whirlpool RBD306PDQ2
Whirlpool RBD306PDQ4
Whirlpool RBD306PDQ6
Whirlpool RBD306PDQ7
Whirlpool RBD306PDQ8
Whirlpool RBD306PDQ9
  #2 (permalink)
Old 02-09-2010, 01:55 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
Replacement parts for WHIRLPOOL RBD275PDQ11 | AppliancePartsPros.com
Here is a tech sheet
http://www.servicematters.com/docs/w...%204451887.pdf
I am assuming that once it hits the set temperature, it runs OK.
It may just need adjusting, see the tech sheet.
The next possible cause would be the temperature sensor.
Following is a good link on how to check it.
Check out #'s 7, 8, 20 and 21.
http://www.applianceaid.com/elecrange.html
It also could be a dirty or bad connection in the sensor circuit.
This is a positive coefficient device re: resistance rises as temperature rises.
So a bad/dirty connection makes the control board think that the oven is hotter than it actually is.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GE XL44 stops heating after reaching temp smoste Oven Repair (including Ranges and Cooktops) 0 02-07-2010 10:49 PM
Electric oven does not hold set temp. John G. Oven Repair (including Ranges and Cooktops) 0 01-22-2010 12:10 PM
GE Tru Temp electric oven mac4141 Oven Repair (including Ranges and Cooktops) 10 03-09-2009 10:43 AM
Oven not reaching temp fpbeck Oven Repair (including Ranges and Cooktops) 0 09-09-2008 11:04 PM
Kitchen AId double oven not reaching temp bobkitchenaid Oven Repair (including Ranges and Cooktops) 0 11-30-2007 09:03 AM
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
