the lower oven won't broil, so I replaced the element. Still won't broil. What can I do next?
Tom, Assuming there is nothing wrong with the wires on the back, the problem most likely is a bad relay board (#81 on the diagram). The oven has to be completely removed from the cabinet for the repair. - The relay board Part number: AP2127302
