| » Oven Igniter Stays On |
Model Number: MGR4410ADH Brand: Maytag Age: More than 10 years
Oven Igniter Stays Glowing,also Must Tap On Burner To Get Lit. But Igniter Stays On. Any Advise Would Be Appreciated.
The oven igniter stays "on" as long as the flame needed to stay "on".
If you have to tap on the burner to let the gas out then it could be a bad igniter or a bad gas safety valve. You have to measure the current drawn by the igniter to find out exactly which part is bad. If it's less than 3.2 amps - replace the igniter. If it's more then 3.2 amps - replace the gas safety valve. - The part number for the oven igniter is AP205873 - The part number for the gas safety valve is AP374297 Here are the break down diagrams for the Maytag range Model MGR4410ADH Gene.
__________________
Professional appliance repair in Los Angeles, California. |
| Display Modes | |
| Oven Light Stays On | washind | Oven Repair (including Ranges and Cooktops) | 3 | 02-26-2008 06:30 PM |
| Oven Stays On | trgtshtr | Oven Repair (including Ranges and Cooktops) | 0 | 02-05-2008 12:31 PM |
| Oven stays on | dbcurrie | Oven Repair (including Ranges and Cooktops) | 0 | 01-22-2008 10:31 AM |
| Oven stays on with switch on the off position | ivan coulombe | Oven Repair (including Ranges and Cooktops) | 1 | 11-27-2007 10:51 PM |
| Igniter Stays On | Fligers | Oven Repair (including Ranges and Cooktops) | 3 | 11-19-2007 12:14 AM |
