Discuss
flame flicker problem
 in
The large burner on my new Dacor 365 (natural gas) has a simmer section (inside) and a main section (outer
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » flame flicker problem
  #1 (permalink)
Old 04-27-2008, 05:25 PM
leeelson leeelson is offline
Junior Member
leeelson is on a distinguished road
Default flame flicker problem
Model Number: pgm 365   Brand: Dacor   Age: 1 - 5 years
The large burner on my new Dacor 365 (natural gas) has a simmer section (inside) and a main section (outer ring). If I slowly increase the setting, the simmer section comes on, then the main section lights. If I increase it still further, the main section increases but the simmer section starts to flicker (part of the flame goes off and on at about a 2 second interval). Then, at the highest setting, part of the simmer burner goes off (no flame). The part that goes off is next to the igniter, so the igniter starts. This happens only when there is a pan above the burner. This has happened since we got the unit (15 months ago), but it's worse now.
This seems like a gas flow problem. The other, smaller simmer burner does not have this problem, but it has a slightly different design (air/gas holes are different). Anyone else have this problem? Any suggestions as to how to adjust this?
Thanks in advance.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Gas Dryer no flame Jimbeau Dryer Repair 1 03-09-2008 06:58 PM
gas oven, flame goes out after being lit rotten Oven Repair (including Ranges and Cooktops) 4 01-25-2008 06:11 PM
flame on than off milhouse Dryer Repair 0 12-30-2007 05:54 PM
No flame after initial start jrileysr Dryer Repair 1 12-08-2007 07:38 PM
High flame in oven cstric1 Oven Repair (including Ranges and Cooktops) 1 12-06-2007 06:13 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
