Discuss
clock/timer bizzare behavior, no fault code
 in
Freestanding electric oven/stove Kenmore/Roper Model: 911.9554591 Age: 12 Fault code: None Oven and stove seem to work fine, the problem
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » clock/timer bizzare behavior, no fault code
  #1 (permalink)
Old 04-24-2008, 02:38 PM
Junior Member
workpot is on a distinguished road
Smile clock/timer bizzare behavior, no fault code
Model Number: 911.9554591   Brand: Kenmore   Age: More than 10 years
Kenmore/Roper
Model: 911.9554591
Fault code: None
Oven and stove seem to work fine, the problem is with the clock/timer. Tried turning the breaker off and then back on and when it comes on it beeps intermittently and the the clock blinks, but neither seem to be at full power. The beeping can hardly be heard at all, and the the clock is so dim I have to cup my hands around it to read it. When I touch any other buttons nothing happens, except when I touch the hour or minute buttons, the beeping changes to one continuous beep.
Of course I don’t want to put anything into this old unit, but I don’t want to replace it yet either. We look forward to remodeling in the next year or so. So my questions are not only how to fix it, but if it is too much, how can I disconnect the clock/timer so it stops beeping until it is replaced? I can live with the blinking, but not the beeping.
Thanks-Rob
Ads By Google
Related Models
Kenmore 911.9967710  KENMORE PORTABLE MICROWAVE OVEN
Kenmore 911.9967910  MICROWAVE
Magic Chef 9112VPV Walloven - Std Gas
Magic Chef 9112VUV Walloven - Std Gas
Magic Chef 9112WPA Walloven - Std Gas
Magic Chef 9112WPW Walloven - Std Gas
Magic Chef 9112WUA Walloven - Std Gas
Magic Chef 9112WUT Walloven - Std Gas
Magic Chef 9112WUV Walloven - Std Gas
Magic Chef 9112XPB Walloven - Std Gas
Magic Chef 9112XUB Walloven - Std Gas
Kenmore 9113012990 GAS OVEN
Kenmore 9113012991 24" GAS BUILT-IN OVEN
Kenmore 9113012992 24" GAS BUILT-IN OVEN
Kenmore 91130158590 24" GAS BUILT-IN OVEN
Kenmore 91130168690 24" GAS BUILT-IN OVEN
Kenmore 91130168791 24" GAS BUILT-IN OVEN
Kenmore 91130168792 24" GAS BUILT-IN OVEN
Kenmore 91130168894 GAS BUILT-IN OVEN
Kenmore 91130169690 24"(GAS BUILT-IN OVEN
Kenmore 91130169791 24" GAS BUILT-IN OVEN
Kenmore 91130169792 24" GAS BUILT-IN OVEN
Kenmore 91130169894 GAS BUILT-IN OVEN
Kenmore 9113018892 GAS BUILT-IN OVEN
Kenmore 9113022190 Wall Oven, Gas
Kenmore 9113022191 24" GAS BUILT-IN OVEN
Kenmore 9113022192 24" GAS BUILT-IN OVEN
Kenmore 9113022990 GAS OVEN
Kenmore 9113022991 24" GAS BUILT-IN OVEN
Kenmore 9113022992 24" GAS BUILT-IN OVEN
Kenmore 9113042590 GAS WALL OVENS
Kenmore 9113042591 EXTENDED DELAYED IGNITION-SELF CLEAN.GAS WALL OVEN
Kenmore 9113042592 EXTENDED DELAYED IGNITION-SELF CLEAN.GAS WALL OVEN
Kenmore 9113042593 EXTENDED DELAYED IGNITION-SELF CLEAN.GAS WALL OVEN
Kenmore 9113042990 ERC TOUCH PADS HARD TO PUSH/F2 CODE-GAS WALL OVENS
Kenmore 9113042991 EXTENDED DELAYED IGNITION-SELF CLEAN.GAS WALL OVEN
Kenmore 9113042992 EXTENDED DELAYED IGNITION-SELF CLEAN.GAS WALL OVEN
Kenmore 9113042993 EXTENDED DELAYED IGNITION-SELF CLEAN.GAS WALL OVEN
Kenmore 91130465690 EXTENDED DELAYED IGNITION-SELF CLEAN.GAS WALL OVEN
Kenmore 91130465791 EXTENDED DELAYED IGNITION-SELF CLEAN.GAS WALL OVEN
Kenmore 91130465792 24" GAS BUILT-IN OVEN
Kenmore 91130465893 24" GAS BUILT-IN OVEN
Kenmore 91130465894 GAS BUILT-IN OVEN
Kenmore 91130469690 EXTENDED DELAYED IGNITION-SELF CLEAN.GAS WALL OVEN
Kenmore 91130469791 EXTENDED DELAYED IGNITION-SELF CLEAN.GAS WALL OVEN
Kenmore 91130469792 24" GAS BUILT-IN OVEN
Kenmore 91130469893 24" GAS BUILT-IN OVEN
Kenmore 91130469894 GAS BUILT-IN OVEN
Kenmore 9113118892 GAS BUILT-IN OVEN
Kenmore 9113128812 GAS BUILT-IN OVEN
Kenmore 9113128892 GAS BUILT-IN OVEN
Kenmore 9113138818 EXTENDED DELAYED IGNITION-SELF CLEAN.GAS WALL OVEN
Kenmore 9113138819 EXTENDED DELAYED IGNITION-SELF CLEAN.GAS WALL OVEN
Kenmore 9113138890 EXTENDED DELAYED IGNITION-SELF CLEAN.GAS WALL OVEN
Kenmore 9113138891 EXTENDED DELAYED IGNITION-SELF CLEAN.GAS WALL OVEN
Kenmore 9113138898 EXTENDED DELAYED IGNITION-SELF CLEAN.GAS WALL OVEN
Kenmore 9113138899 EXTENDED DELAYED IGNITION-SELF CLEAN.GAS WALL OVEN
Kenmore 9113302090 36" GAS COUNTER UNIT
Kenmore 9113302190 36" GAS COUNTER UNIT
Kenmore 9113312591 GAS COUNTER UNIT
Kenmore 9113312592 GAS COUNTER UNIT
Kenmore 9113312593 GAS COUNTER UNIT
Kenmore 9113312991 GAS COUNTER UNIT
Kenmore 9113312992 GAS COUNTER UNIT
Kenmore 9113312993 GAS COUNTER UNIT
Kenmore 91133202100 30" GAS COOKTOP
Kenmore 91133202101 30" GAS COOKTOP
Kenmore 91133203100 30" GAS COOKTOP
Kenmore 91133203101 30" GAS COOKTOP
Kenmore 91133204100 30" GAS COOKTOP
Kenmore 91133204101 30" GAS COOKTOP
Kenmore 91133209100 30" GAS COOKTOP
Kenmore 91133209101 30" GAS COOKTOP
Kenmore 91133212100 COOKTOP
Kenmore 91133212101 36" GAS COOKTOP
Kenmore 91133213100 36" GAS COOKTOP
Kenmore 91133213101 36" GAS COOKTOP
Kenmore 91133214100 36" GAS COOKTOP
Kenmore 91133219100 COOKTOP
Kenmore 91133219101 36" GAS COOKTOP
Kenmore 91133255590 RANGE
Kenmore 91133255591 36" GAS COUNTER UNIT
Kenmore 91133255592 36" GAS COUNTER UNIT
Kenmore 91133259590 RANGE
Kenmore 91133259591 36" GAS COUNTER UNIT
Kenmore 91133285091 COOKTOP
Kenmore 91133285890 36" GAS COUNTER UNIT
Kenmore 91133289091 COOKTOP
Kenmore 91133289890 36" GAS COUNTER UNIT
Kenmore 91133355590 RANGE
Kenmore 91133355591 36" GAS COUNTER UNIT
Kenmore 91133355592 36" GAS COUNTER
Kenmore 91133356590 RANGE
Kenmore 91133356591 36" GAS COUNTER UNIT
Kenmore 91133359590 RANGE
Kenmore 91133359591 36" GAS COUNTER UNIT
Kenmore 91133384100 36" GAS COOKTOP
Kenmore 91133384101 36" GAS COOKTOP
Kenmore 91133385100 36" GAS COOKTOP
Kenmore 91133385890 36" GAS COUNTER UNIT
Kenmore 91133386890 36" GAS COUNTER UNIT
Kenmore 91133389100 36" GAS COOKTOP
Kenmore 91133389890 36" GAS COUNTER UNIT
Kenmore 9114012190 ELEC BUILT-IN OVEN
Kenmore 9114012191 ELEC BUILT-IN OVEN
Kenmore 9114012192 24" ELECTRIC BUILT-IN OVEN
Kenmore 9114012193 24" ELECTRIC BUILT-IN OVEN
Kenmore 9114012990 ELEC BUILT-IN OVEN
Kenmore 9114012991 ELEC BUILT-IN OVEN
Kenmore 9114012992 24" ELECTRIC BUILT-IN OVEN
Kenmore 9114012993 24" ELECTRIC BUILT-IN OVEN
Kenmore 91140161690 24" ELECTRIC BUILT-IN OVEN
Kenmore 91140161791 24" ELECTRIC BUILT-IN OVEN
Kenmore 91140161792 24" ELECTRIC BUILT-IN OVEN
Kenmore 91140168792 24" ELECTRIC BUILT-IN OVEN
Kenmore 91140169690 24" ELECTRIC BUILT-IN OVEN
Kenmore 91140169791 24" ELECTRIC BUILT-IN OVEN
Kenmore 91140169792 24" ELECTRIC BUILT-IN OVEN
Kenmore 9114018813 ELECTRIC BUIL-IN OVEN
Kenmore 9114018893 ELECTRIC BUIL-IN OVEN
  #2 (permalink)
Old 04-25-2008, 03:17 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Rob,
The problem with your range is a bad Electronic Range Control (ERC) which has to be replaced. The buzzer is a part of the ERC and can not be disconnected. You can disconnect the whole ERC, but you would not be able to use the oven.
You can buy the new ERC from Appliance Parts Pros for $143.38
- The part number for the ERC is AP2025191
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Fault Code kdh Washer Repair 3 10-09-2009 11:41 AM
DLF Fault Code jewel4477 Washer Repair 7 07-13-2009 04:54 PM
Lg ref fault code mwill5 Refrigerator & Freezer Repair 0 01-02-2009 09:58 AM
fault code f-9 Lou Barta Microwave Repair 1 04-03-2008 07:26 PM
F0 fault code William Oven Repair (including Ranges and Cooktops) 0 10-10-2007 06:13 PM
