| » Frigidaire Oven Blew breaker, quit working |
Model Number: FEF366ECE Brand: Frigidaire Age: 1 - 5 years
I've taken apart the back of the oven and found that the terminal block is melted a little where the red wire connects. Also the first inch of the red casing on the power wire is burned--lots of black carbon on wire and contact. The Electonic Oven Control (Clock/Timer/etc.) shows no signs of burned or melted solder. It's only 2.5 years old, normal use. Any ideas? Should I replace the EOC and the Terminal block?
I forgot to mention a few details: I was able to reset the breaker two times after the initial blow-out. The EOC/clock/timer would light up and I was able to heat the oven and the burners. After I tested Bake for 5 minutes the breaker blew with a popping noise. I reset the breaker and tested Broil. It blew after 5 minutes also. After that I could not get the breaker to stay on.
| Display Modes | |
| Frigidaire oven blew element, top & control works, I fixed it ! | Aaron 1874 | Oven Repair (including Ranges and Cooktops) | 0 | 12-31-2009 07:18 AM |
| kenmore washer blew the breaker | ebontrager | Washer Repair | 1 | 08-10-2009 02:12 PM |
| Frigidaire oven quit heating | cottonbroker | Oven Repair (including Ranges and Cooktops) | 12 | 04-10-2009 04:25 PM |
| Oven quit working again!! | mauscuba | Oven Repair (including Ranges and Cooktops) | 0 | 01-11-2009 09:24 AM |
| Light Switch Shorted- blew breaker | gregjen | Refrigerator & Freezer Repair | 1 | 09-28-2007 02:39 AM |
