Discuss
Amana Caloiric Oven Gas Flow Problem
 in
Replaced the Dual Gas Valve in the subject unit because the Bake Ignitor would come on, glow brightly and maybe
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Amana Caloiric Oven Gas Flow Problem
  #1 (permalink)
Old 04-23-2008, 10:16 AM
ljbean ljbean is offline
Junior Member
ljbean is on a distinguished road
Default Amana Caloiric Oven Gas Flow Problem
Model Number: RSF3300UW   Brand: Amana   Age: More than 10 years
Replaced the Dual Gas Valve in the subject unit because the Bake Ignitor would come on, glow brightly and maybe and maybe not the Bake side of the valve would open. Broiling side works fine. Baking side of new valve will not open even though Ignitor is glowing brightly. And, again, Broiling funtion works fine. Checked voltage between Ignitor and Valve. It was around 3 vac hooked to valve and 118 vac checking with lead disconnected from valve. Can't figure this one out. Any suggestions?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 04-23-2008, 03:24 PM
misterfixall misterfixall is offline
Senior Expert
APP Volunteer
misterfixall is on a distinguished road
Default
replace bake ignitor
__________________
  #3 (permalink)
Old 04-28-2008, 02:15 PM
Junior Member
Default Amana Caloric Oven Gas Flow Problem
That Fixed it! Thank You Very Much!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Amana Refrigerator drain freeze problem Scottrse1 Refrigerator & Freezer Repair 7 09-05-2008 06:34 PM
Amana frig Freezer defrost problem ct2023 Refrigerator & Freezer Repair 1 04-09-2008 01:46 PM
Amana Dryer Problem js02673 Dryer Repair 1 01-28-2008 11:33 AM
water disp on fridg(amana) door problem lemajune Refrigerator & Freezer Repair 9 11-14-2007 05:52 AM
Problem with Amana oven it just does not turn on nadmit Oven Repair (including Ranges and Cooktops) 1 10-22-2007 08:51 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
