Discuss
igniter keeps sparking even after lighting up
 in
i have a 36" 6 burner viking cooktop. occassionally, the igniter keeps sparking for awhile after the burner is lit,
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » igniter keeps sparking even after lighting up
  #1 (permalink)
Old 02-01-2010, 06:12 PM
Junior Member
jsoliveri is on a distinguished road
Default igniter keeps sparking even after lighting up
Model Number: 36vgsu   Brand: -other-   Age: 5 - 10 years
i have a 36" 6 burner viking cooktop. occassionally, the igniter keeps sparking for awhile after the burner is lit, but does stop. this occurs only on some of the burners.
now, the burners that this affected do not light unless i use a match. the igniter keeps sparking even after this is lit and only stops when i shut the burner off.
recently, a teapot exploded over the stove and the water spilled on the unit. water did drip from the bottom of the pan inside the cabinet
what can i take a part, clean? anything on the top?
Ads By Google
Related Models
Frigidaire 37-0007-00-02 Tap(v1) / Electric Range
Frigidaire 37-0007-00-03 Tap(v3) / Electric Range
Frigidaire 37-0007-00-04 Tap(v0) / Electric Range
Frigidaire 37-0007-00-05 Tap(v5) / Electric Range
Frigidaire 37-0007-00-06 Tap(v1) / Electric Range
Frigidaire 37-0007-00-07 Tap(v3) / Electric Range
Frigidaire 37-0007-23-02 Tap(v2) / Electric Range
Frigidaire 37-0007-23-03 Tap(v4) / Electric Range
Frigidaire 37-0007-23-05 Tap(v6) / Electric Range
Frigidaire 37-0007-23-06 Tap(v2) / Electric Range
Frigidaire 37-0007-23-07 Tap(v4) / Electric Range
Frigidaire 37-0117 ELECTRIC RANGE
Frigidaire 37-0117-00-02 Tap(v1) / Electric Range
Frigidaire 37-0117-00-03 Tap(v3) / Electric Range
Frigidaire 37-0117-23-02 Tap(v2) / Electric Range
Frigidaire 37-0117-23-03 Tap(v4) / Electric Range
Frigidaire 37-1004-00-01 Tap(v1) / Electric Range
Frigidaire 37-1004-23-01 Tap(v2) / Electric Range
Frigidaire 37-1007-00-01 Tap(v1) / Electric Range
Frigidaire 37-1007-00-02 Tap(v4) / Electric Range
Frigidaire 37-1007-00-03 Tap(v7) / Electric Range
Frigidaire 37-1007-00-04 Tap(v10) / Electric Range
Frigidaire 37-1007-00-05 Tap(v1) / Electric Range
Frigidaire 37-1007-23-01 Tap(v2) / Electric Range
Frigidaire 37-1007-23-02 Tap(v5) / Electric Range
Frigidaire 37-1007-23-03 Tap(v8) / Electric Range
Frigidaire 37-1007-23-04 Tap(v11) / Electric Range
Frigidaire 37-1007-23-05 Tap(v2) / Electric Range
Frigidaire 37-1007-66-01 Tap(v3) / Electric Range
Frigidaire 37-1007-66-02 Tap(v6) / Electric Range
Frigidaire 37-1007-66-03 Tap(v9) / Electric Range
Frigidaire 37-1007-66-04 Tap(v12) / Electric Range
Frigidaire 37-1007-66-05 Tap(v3) / Electric Range
Frigidaire 37-1009-00-01 Tap(v1) / Electric Range
Frigidaire 37-1009-00-02 Tap(v3) / Electric Range
Frigidaire 37-1009-00-03 Tap(v5) / Electric Range
Frigidaire 37-1009-00-04 Tap(v1) / Electric Range
Frigidaire 37-1009-00-05 Tap(v1) / Electric Range
Frigidaire 37-1009-00-06 Tap(v1) / Electric Range
Frigidaire 37-1009-23-01 Tap(v2) / Electric Range
Frigidaire 37-1009-23-02 Tap(v4) / Electric Range
Frigidaire 37-1009-23-03 Tap(v6) / Electric Range
Frigidaire 37-1009-23-04 Tap(v2) / Electric Range
Frigidaire 37-1009-23-05 Tap(v2) / Electric Range
Frigidaire 37-1009-23-06 Tap(v2) / Electric Range
Frigidaire 37-1012-23-01 Tap(v2)
Frigidaire 37-1012-23-02 Tap(v6)
Frigidaire 37-1012-23-03 Tap(v10)
Frigidaire 37-1012-23-04 Tap(v14)
Frigidaire 37-1012-23-05 Tap(v18)
Frigidaire 37-1012-57-01 Tap(v3)
Frigidaire 37-1012-57-02 Tap(v7)
Frigidaire 37-1012-57-03 Tap(v11)
Frigidaire 37-1012-57-04 Tap(v15)
Frigidaire 37-1012-57-05 Tap(v19)
Frigidaire 37-1012-66-01 Tap(v4)
Frigidaire 37-1012-66-02 Tap(v8)
Frigidaire 37-1012-66-03 Tap(v12)
Frigidaire 37-1012-66-04 Tap(v16)
Frigidaire 37-1012-66-05 Tap(v20)
Frigidaire 37-1015-00-01 Tap(v1)
Frigidaire 37-1015-00-02 Tap(v5)
Frigidaire 37-1015-00-03 Tap(v9)
Frigidaire 37-1015-00-04 Tap(v13)
Frigidaire 37-1015-00-05 Tap(v17)
Frigidaire 37-1022-00-01 Tap(v1)
Frigidaire 37-1022-00-02 Tap(v5)
Frigidaire 37-1022-00-03 Tap(v9)
Frigidaire 37-1022-00-04 Tap(v13)
Frigidaire 37-1022-23-02 Tap(v6)
Frigidaire 37-1022-23-03 Tap(v10)
Frigidaire 37-1022-23-04 Tap(v14)
Frigidaire 37-1022-57-01 Tap(v3)
Frigidaire 37-1022-57-02 Tap(v7)
Frigidaire 37-1022-57-03 Tap(v11)
Frigidaire 37-1022-57-04 Tap(v15)
Frigidaire 37-1022-66-01 Tap(v4)
Frigidaire 37-1022-66-02 Tap(v8)
Frigidaire 37-1022-66-03 Tap(v12)
Frigidaire 37-1022-66-04 Tap(v16)
Frigidaire 37-1028-00-01 Tap(v1) / Electric Range
Frigidaire 37-1028-23-01 Tap(v2) / Electric Range
Frigidaire 37-1039-00-01 Tap(v1) / Electric Range
Frigidaire 37-1039-00-02 Tap(v3) / Electric Range
Frigidaire 37-1039-00-03 Tap(v1) / Electric Range
Frigidaire 37-1039-00-04 Tap(v1) / Electric Range
Frigidaire 37-1039-00-05 Tap(v1) / Electric Range
Frigidaire 37-1039-23-01 Tap(v2) / Electric Range
Frigidaire 37-1039-23-02 Tap(v4) / Electric Range
Frigidaire 37-1039-23-03 Tap(v2) / Electric Range
Frigidaire 37-1039-23-04 Tap(v2) / Electric Range
Frigidaire 37-1039-23-05 Tap(v2) / Electric Range
Frigidaire 37-1042-00-01 Tap(v1) / Electric Range
Frigidaire 37-1042-00-02 Tap(v2) / Electric Range
Frigidaire 37-1042-00-03 Tap(v3) / Electric Range
Frigidaire 37-1042-00-04 Tap(v4) / Electric Range
Frigidaire 37-1042-00-05 Tap(v5) / Electric Range
Frigidaire 37-1042-23-01 Tap(v6) / Electric Range
Frigidaire 37-1042-23-02 Tap(v7) / Electric Range
Frigidaire 37-1042-23-03 Tap(v8) / Electric Range
Frigidaire 37-1042-23-04 Tap(v9) / Electric Range
Frigidaire 37-1042-23-05 Tap(v10) / Electric Range
Frigidaire 37-1042-66-04 Tap(v11) / Electric Range
Frigidaire 37-1048-00-01 Tap(v1) / Electric Range
Frigidaire 37-1048-00-02 Tap(v4) / Electric Range
Frigidaire 37-1048-00-03 Tap(v7) / Electric Range
Frigidaire 37-1048-00-04 Tap(v10) / Electric Range
Frigidaire 37-1048-00-05 Tap(v1) / Electric Range
Frigidaire 37-1048-23-01 Tap(v2) / Electric Range
Frigidaire 37-1048-23-02 Tap(v5) / Electric Range
Frigidaire 37-1048-23-03 Tap(v8) / Electric Range
Frigidaire 37-1048-23-04 Tap(v11) / Electric Range
Frigidaire 37-1048-23-05 Tap(v2) / Electric Range
Frigidaire 37-1048-66-01 Tap(v3) / Electric Range
Frigidaire 37-1048-66-02 Tap(v6) / Electric Range
Frigidaire 37-1048-66-03 Tap(v9) / Electric Range
Frigidaire 37-1048-66-04 Tap(v12) / Electric Range
Frigidaire 37-1048-66-05 Tap(v3) / Electric Range
Frigidaire 37-1117-00-01 Tap(v1) / Electric Range
Frigidaire 37-1117-00-02 Tap(v4) / Electric Range
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
DCS Grill Top Igniter not lighting. ktcox67 Oven Repair (including Ranges and Cooktops) 0 11-14-2009 07:32 PM
magnetron sparking? dvcant5 Microwave Repair 0 10-04-2009 12:42 PM
Thermador igniter keeps clicking even after lighting gosokol Oven Repair (including Ranges and Cooktops) 0 09-26-2009 03:11 PM
Gas dryer with new fuse, thermostat & igniter. Igniter did NOT glow & no heat yzhong Dryer Repair 1 08-10-2009 04:03 PM
GE Microwave sparking katlatigo Microwave Repair 1 01-20-2009 09:27 AM
