Discuss
Oven works but temperature way off.
 in
The oven does heat but temperature is off -25 @ 200 and over -150 @ 550. Suspect AP4009456 oven sensor
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Oven works but temperature way off.
  #1 (permalink)
Old 02-01-2010, 02:28 PM
Junior Member
ah_clem is on a distinguished road
Default Oven works but temperature way off.
Model Number: CRG9700AAL   Brand: Maytag   Age: 5 - 10 years
The oven does heat but temperature is off -25 @ 200 and over -150 @ 550. Suspect AP4009456 oven sensor and would like to know the resistance/temperature values so that I can test it. The oven does maintain temperature but the temperature is incorrect. Another repair person suggested the ignitor so I swapped the ignitor from the broiler burner with the one for the oven burner. This had no effect. Seems to me that either the oven sensor or controller (yikes that's expensive) is at fault. I would like to avoid just replacing the oven sensor since I'm not sure that's the problem.
If it's the controller, it's time for a new oven as far as I can justify.
Thanks in advance,
Ah
Ads By Google
Related Models
Maytag CRG9700AAL Range - S/c F/s Gas
Maytag CRG9700AAW Range - S/c F/s Gas
Maytag CRG9700BAL Range - S/c F/s Gas
Maytag CRG9700BAW Range - S/c F/s Gas
Maytag CRG9700CAE Range - S/c F/s Gas
Maytag CRG9700CAL Range - S/c F/s Gas
Maytag CRG9700CAM Range - S/c F/s Gas
Maytag CRG9700CAW Range - S/c F/s Gas
International CRG9700CGE Range - S/c F/s Gas
International CRG9700CGM Range - S/c F/s Gas
Maytag CRG9800AAB Range - S/c F/s Gas
Maytag CRG9800AAE Range - S/c F/s Gas
Maytag CRG9800AAL Range - S/c F/s Gas
Maytag CRG9800AAW Range - S/c F/s Gas
Maytag CRG9800BAB Range - S/c F/s Gas
Maytag CRG9800BAE Range - S/c F/s Gas
Maytag CRG9800BAL Range - S/c F/s Gas
Maytag CRG9800BAM Range - S/c F/s Gas
Maytag CRG9800BAW Range - S/c F/s Gas
Maytag CRG9800CAB Range - S/c F/s Gas
Maytag CRG9800CAE Range - S/c F/s Gas
Maytag CRG9800CAM Range - S/c F/s Gas
Maytag CRG9830CAB Range - S/c F/s Gas
Maytag CRG9830CAE Range - S/c F/s Gas
Maytag CRG9830CAM Range - S/c F/s Gas
Admiral CRGA250AAL Range - F/s Std Gas
Admiral CRGA250AAW Range - F/s Std Gas
Admiral CRGA250BAL Range - F/s Std Gas
Admiral CRGA250BAW Range - F/s Std Gas
Admiral CRGA300AAL Range - F/s Std Gas
Admiral CRGA300AAW Range - F/s Std Gas
Admiral CRGA300BAL Range - F/s Std Gas
Admiral CRGA300BAW Range - F/s Std Gas
Admiral CRGA350AAL Range - F/s Std Gas
Admiral CRGA350AAW Range - F/s Std Gas
Admiral CRGA400AAL Range - F/s Std Gas
Admiral CRGA400AAW Range - F/s Std Gas
Admiral CRGA400BAL Range - F/s Std Gas
Admiral CRGA400BAW Range - F/s Std Gas
Admiral CRGA500AAL Range - F/s Std Gas
Admiral CRGA500AAW Range - F/s Std Gas
Admiral CRGA600AAL Range - S/c F/s Gas
Admiral CRGA600AAW Range - S/c F/s Gas
Admiral CRGA650AAL Range - S/c F/s Gas
Admiral CRGA650AAW Range - S/c F/s Gas
Admiral CRGA700AAL Range - S/c F/s Gas
Admiral CRGA700AAW Range - S/c F/s Gas
Admiral CRGA800AAE Range - F/s Std Gas
Admiral CRGA800AAL Range - F/s Std Gas
Admiral CRGA800AAW Range - F/s Std Gas
Frigidaire CRGF342AS0 Dryer - Frigidaire/best Buy
Frigidaire CRGF342AS1 Dryer - Frig/best Buy
Frigidaire CRGF342AS2 Frigidaire/gas Range
Frigidaire CRGF342AS3 Frigidaire/gas Dryer
Frigidaire CRGF342AS4 Frigidaire/dryer
Frigidaire CRGR442AS0 Dryer - Frig/best Buy
Frigidaire CRGR442AS1 Dryer - Frig/best Buy
Frigidaire CRGR442AS2 Dryer - Frig/best Buy
Frigidaire CRGR5700AS0 Dryer - Frig/best Buy
Frigidaire CRGR5700AS1 Frigidaire/gas Dryer
Frigidaire CRGR5700AS2 Frigidaire/gas Dryer
Frigidaire CRGR5700AS3 Frigidaire/dryer
Frigidaire CRGR7900AS0 Dryer - Frig/best Buy
Frigidaire CRGR7900AS1 Frigidaire/gas Dryer
Frigidaire CRGR7900AS2 Frigidaire/gas Dryer
Frigidaire CRGR7900AS3 Frigidaire/dryer
Amana CRH4-1 Commercial Microwaves
Amana CRH4-3 Commercial Microwaves
Amana CRH5-1 Commercial Microwaves
Amana CRH5-3 Commercial Microwaves
International CRL5300BXA Range - F/s Std Gas
International CRL5300BXW Range - F/s Std Gas
International CRL5300CXL Range - F/s Std Gas
International CRL5300CXW Range - F/s Std Gas
International CRL5300DXL Range - F/s Std Gas
International CRL5300DXT Range - F/s Std Gas
International CRL5300DXW Range - F/s Std Gas
International CRL7400CAL Range - F/s Std Gas
International CRL7400CAW Range - F/s Std Gas
Amana CRMC-20B Mwave - Family Size (60 Hz)
Amana CRMC-30 Range - S/c S/i Ddraft Gas
Amana CRMC720 Microwave - Convection
Maytag CRP200 Range - F/s Std Gas
Maytag CRP200B Range - F/s Std Gas
Maytag CRP205 Range - F/s Std Gas
Maytag CRP300 Range - F/s Std Gas
Maytag CRP300B Range - F/s Std Gas
Maytag CRP382 Range - F/s Std Gas
Maytag CRP382B Range - F/s Std Gas
Maytag CRP5300AXL Range - F/s Std Gas
Maytag CRP5300AXW Range - F/s Std Gas
Admiral CRPA200AXL Range - F/s Std Gas
Admiral CRPA200AXW Range - F/s Std Gas
Admiral CRPA200BXL Range - F/s Std Gas
Admiral CRPA200BXW Range - F/s Std Gas
Amana CRR-1225 Mwave - Cntrtp / Stand Alone
Amana CRR-5B Mwave - Cntrtp / Stand Alone
Amana CRR-7B Mwave - Family Size (60 Hz)
Amana CRR-9TB Mwave - Family Size (60 Hz)
Amana CRR1220 Mwave - Cntrtp / Stand Alone
Amana CRRL-5C Mwave - Family Size (60 Hz)
Amana CRRL-5D Mwave - Cntrtp / Stand Alone
Amana CRRL-700 Mwave - Cntrtp / Stand Alone
Amana CRRL-8TD Mwave - Family Size (60 Hz)
Amana CRRL-8X Mwave - Cntrtp / Stand Alone
Amana CRRL-8XA Mwave - Cntrtp / Stand Alone
Amana CRRL-9TB Mwave - Family Size (60 Hz)
Amana CRRL-9TC Mwave - Cntrtp / Stand Alone
Amana CRRL1020 Mwave - Cntrtp / Stand Alone
Amana CRRL920 Mwave - Cntrtp / Stand Alone
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Wall oven bake element not working! Broil works, clock works. ajachyra Oven Repair (including Ranges and Cooktops) 1 12-02-2009 06:30 AM
Oven will not turn on, broiler works, stove top works caewart Oven Repair (including Ranges and Cooktops) 1 06-20-2009 05:25 AM
Oven works but not heating to required temperature vaughans Oven Repair (including Ranges and Cooktops) 1 11-21-2008 10:27 AM
GE oven stove top works, ignitor works, no gas flow in oven mikeburton@cableone.net Oven Repair (including Ranges and Cooktops) 1 12-26-2007 07:09 PM
Freezer works fine but refrigerator does not hold temperature mikel500 Refrigerator & Freezer Repair 0 10-16-2007 05:57 AM
