Element won't heat up (20ohms on element and 120volts to the element)?
Brand: GE Age: More than 10 years
I got an old drop-in GE. On the bake setting the bake element is not heating. I pulled the element out on tested the resistance. There is a resistance @ 20ohms. I than tested the power that connects to the element terminals, the voltage is 120volts. I attached the element back to the terminals and the element will not heat?? The voltage at the termainals with the element connected reads prox 6 volts?? Any ides why the element will not heat?? Why does the volatge drop to 6 volts when I attach the element?
I think 20ohms is normal for a bake element?
I looked at the schematic and it looks like the bake element should be 240v (red and black wire) but with the element disconnected there is 120v?? Thoughts?
Jesse
Ads By Google
