| » KitchenAid Oven - element will not turn on |
Model Number: KERC601HBL6 Brand: Kitchen Aid Age: 5 - 10 years
When I turn on the oven via the touch-pad controls, the heating element never gets hot.
I tested the element for continuity and it is good. I thought the sensor/thermostat was bad so I replace it. That did not fix the problem. Then I replaced the microcptr that is down low behind a side panel. Part number is: AP3085947. This did not correct my problem. I've put it through the end of service test sequence. It goes through all of them: Eb:5l (ELE) Series of number 185-190ish (155-165ish) <<what is normal? 1-:06 2-:06 3-:06 4-:06 5-:06 6-:06 Anyone know how to determine if I need to replace the other microcptr? Now I am considering replacing the other microcptr which is under the touchpad area. This part number is: AP3137865 Ads By Google Related Models |
Replacement parts for WHIRLPOOL KERC601HBL6 | AppliancePartsPros.com Here is the tech sheet http://www.servicematters.com/docs/w...%209754365.pdf When I turn on the oven via the touch-pad controls, the heating element never gets hot. Do any of the elements heat up? You will notice that there is a relay in-line with all the elements, Item 30 in Section 3. Also it shows an fuse but I could not find out where this was using the parts breakdown. Perhaps someone who knows where it is will jump in. If not you will have to trace the wires back to find it, if this unit has one. I tested the element for continuity and it is good. I thought the sensor/thermostat was bad so I replace it. That did not fix the problem. Then I replaced the microcptr that is down low behind a side panel. Part number is: AP3085947. This did not correct my problem. Now I am considering replacing the other microcptr which is under the touchpad area. This part number is: AP3137865 Personally I would not throw a lot of money at this unit. Looks like the keypad is already a pain obtain, so it is well along the way to obsolescence.
__________________
| Display Modes | |
| kitchenaid stove wont turn off | dcjcdc | Oven Repair (including Ranges and Cooktops) | 2 | 01-04-2010 11:01 AM |
| Whirlpool Oven Upper Heating Element won't turn off | ilfang | Oven Repair (including Ranges and Cooktops) | 1 | 01-18-2009 07:41 PM |
| Kitchenaid mixer won't turn on | andyb_22 | General Talk | 3 | 11-25-2008 01:04 PM |
| KitchenAid electric range burners won't turn on | djfancy | Oven Repair (including Ranges and Cooktops) | 0 | 06-18-2008 08:46 PM |
