| » New igniter, gas flows, gas won't lite. |
Model Number: FGP305KW0 Brand: Roper Age: 1 - 5 years
Changed the igniter, we now get gas flow, but the gas will not ignite, wondering if the new igniter gets hot enough to ignite the gas.
It is rare the gas will not ignite! You may have mounted the new igniter too far from the gas ports, or your regulator is defective and causing a weak gas flow.
Also, make sure the voltage to the igniter is 115 volts. If everything checks out ok, I would call a pro. to look at it. You might lite the gas with a match and check for gas purity by observing the flame.
__________________
| Display Modes | |
| My ice over flows | Starflight | Refrigerator & Freezer Repair | 0 | 04-04-2008 04:15 PM |
| Sink water flows into dishwasher then onto floor | kysh | Dishwasher Repair | 1 | 03-27-2008 01:18 PM |
| Whirlpool LA5300XM Cold water trickles, warm water flows properly | ajaysheetal | Washer Repair | 2 | 02-14-2008 05:49 PM |
| oven will not lite | schautz86 | Oven Repair (including Ranges and Cooktops) | 1 | 02-11-2008 01:56 PM |
| Oven won't lite? | Chris7525 | Oven Repair (including Ranges and Cooktops) | 6 | 11-12-2007 07:14 AM |
