Appliance Repair Forum
-   Oven Repair (including Ranges and Cooktops) (http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/)
-   -   Whirlpool oven overheating (http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/7431-whirlpool-oven-overheating.html)
rovingj 04-22-2008 10:58 AM
Set oven to Bake @ 350. The top elements (broiling element) comes on and heats the oven very hot. This display indicates the oven reaches 350 and clicks off, but the top element continues to heat to 500+ when I manually turn oven off.
The temperature sensor was replaced last month.
Does this sound like the controller needs to be replaced?
rovingj 04-23-2008 02:23 PM
Anyone care to comment on this problem....Thanks
Gene 04-24-2008 01:23 PM
Most likely the problem is a bad control board. For more accurate advise we need the complete model number of the oven.
rovingj 04-24-2008 05:32 PM
Thanks, I've went ahead and ordered a new control board....guess I'll just wait and see what happens then.
livio 10-05-2013 10:15 AM
oven top part overheats
I have the exact same problem! did you find a solution?
