Discuss
controller/display blacks-out
 in
My oven controller/display blacks-out (loses power) when the oven is in operation. When the oven cools the display returns. I
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » controller/display blacks-out
  #1 (permalink)
Old 01-30-2010, 12:47 PM
Junior Member
midwayyankee is on a distinguished road
Default controller/display blacks-out
Model Number: acs3350as   Brand: Amana   Age: 5 - 10 years
My oven controller/display blacks-out (loses power) when the oven is in operation. When the oven cools the display returns. I have removed the stove top to access the controller , but see no visible signs of damage to the wiring or the circuit board. The controller is not available any more.Was there a problem with this specific model?
Ads By Google
Related Models
Amana ACS3350AS Range - S/c S/i Gas
Amana ACS3350AW Range - S/c S/i Gas
Amana ACS4140BB Range - S/c S/i Ele
Amana ACS4140BW Range - S/c S/i Ele
Amana ACS4250AB Range - S/c S/i Ele
Amana ACS4250AC Range - S/c S/i Ele
Amana ACS4250AW Range - S/c S/i Ele
Amana ACS4660AB  Range - S/c S/i Ddraft Ele
Amana ACS4660AW  Range - S/c S/i Ddraft Ele
Whirlpool ACS50
Whirlpool ACS501
Whirlpool ACS502
Whirlpool ACS520XA1
Whirlpool ACS602XM
Whirlpool ACS602XT0
Amana ACS7270AB Range - S/c S/i Ele
Amana ACS7270AS Range - S/c S/i Ele
Amana ACS7270AW Range - S/c S/i Ele
Whirlpool ACS802XM
Whirlpool ACS802XT0
Whirlpool ACS802XV0
Whirlpool ACS802XV1
Amana ACS902W  Frigidaire/refrigerator
General Electric ACSK15AH01 Pers elect
General Electric ACSK15AJ01 Pers elect
Amana ACT100E Range - S/c S/i Ddraft Gas
Amana ACT100W Ele Cartridge
Amana ACT100WW Range - S/c S/i Ddraft Gas
Amana ACT101E Ele Cartridge
Amana ACT101WW Range - S/c S/i Ddraft Gas
Amana ACT11 Freezer - Chest
Amana ACT110E Range - S/c S/i Ddraft Gas
Amana ACT110W Range - S/c S/i Ddraft Gas
Amana ACT110WW Range - S/c S/i Ddraft Gas
Amana ACT111E Ele Cartridge
Amana ACT111WW Range - S/c S/i Ddraft Gas
General Electric ACTK15AH01 Pers elect
General Electric ACTK15AJ01 Pers elect
Amana ACU-514 Range - S/c S/i Ddraft Gas
Amana ACU-514C Range - S/c S/i Ddraft Gas
Amana ACU-514D Range - S/c S/i Ddraft Gas
Amana ACU-514E Range - S/c S/i Ddraft Gas
Amana ACU-514F Range - S/c S/i Ddraft Gas
Amana ACU-516 Range - S/c S/i Ddraft Gas
Amana ACU-516A Range - S/c S/i Ddraft Gas
Amana ACU-516C Range - S/c S/i Ddraft Gas
Amana ACU-516D Range - S/c S/i Ddraft Gas
Amana ACU-516F Range - S/c S/i Ddraft Gas
General Electric ACU06LAM1 Room air conditioner
Whirlpool ACU072PK0 Through - the - Wall Air Conditioner
Whirlpool ACU072XE0
Whirlpool ACU072XE1
Whirlpool ACU072XE2
Whirlpool ACU072XE3
Whirlpool ACU072XH0
Whirlpool ACU072XJ0
Whirlpool ACU072XJ1
Whirlpool ACU082XA0
Whirlpool ACU082XD0
Whirlpool ACU082XD1
Whirlpool ACU082XW0
Whirlpool ACU082XX0
Whirlpool ACU082XX1
Whirlpool ACU088PP0 Air Conditioner
Whirlpool ACU088PR0 Air Conditioner
Whirlpool ACU088PR1 Air Conditioner
Whirlpool ACU102PK0 Through - the - Wall Air Conditioner
Whirlpool ACU102PK1 Through - the - Wall Air Conditioner
Whirlpool ACU102PK2 Through - the - Wall Air Conditioner
Whirlpool ACU102XE0
Whirlpool ACU102XE1
Whirlpool ACU102XE2
Whirlpool ACU102XE3
Whirlpool ACU102XH0
Whirlpool ACU102XJ0
Whirlpool ACU102XJ1
Whirlpool ACU102XX0
Whirlpool ACU102XX1
Whirlpool ACU104PK0 Through - the - Wall Air Conditioner
Whirlpool ACU104PK1 Through - the - Wall Air Conditioner
Whirlpool ACU104PM0 Through - the - Wall Air Conditioner
Whirlpool ACU104XH0
Whirlpool ACU104XJ0
Whirlpool ACU104XJ1
Whirlpool ACU108PP0 Air Conditioner
Whirlpool ACU108PR0 Air Conditioner
Whirlpool ACU109PP0 Air Conditioner
Whirlpool ACU109PR0 Air Conditioner
Whirlpool ACU114XE0
Whirlpool ACU114XE1
Whirlpool ACU114XE2
Whirlpool ACU114XE3
Whirlpool ACU114XE4
Whirlpool ACU114XH0
Whirlpool ACU124PK0 Through - the - Wall Air Conditioner
Whirlpool ACU124PK1 Through - the - Wall Air Conditioner
Whirlpool ACU124PK2
Whirlpool ACU124PM0 Through - the - Wall Air Conditioner
Whirlpool ACU124PP0 Air Conditioner
Whirlpool ACU124XA0
Whirlpool ACU124XD0
Whirlpool ACU124XD1
Whirlpool ACU124XJ0
Whirlpool ACU124XJ1
Whirlpool ACU124XX0
Whirlpool ACU124XX1
Whirlpool ACU129PP0 Air Conditioner
Whirlpool ACU129PR0 Air Conditioner
Whirlpool ACV052XG0
Whirlpool ACV052XG1
Whirlpool ACV052XH0
General Electric ACV05LAB1 Room air conditioner
General Electric ACV05LAB2 Room air conditioner
General Electric ACV05LAB3 Room air conditioner
General Electric ACV05LAB4 Room air conditioner
  #2 (permalink)
Old 01-31-2010, 05:45 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
Replacement parts for AMANA ACS3350AS Range - S/c S/i Gas | AppliancePartsPros.com
Here is a tech sheet
http://www.servicematters.com/maytag.../T231_15R0.pdf
Here is a manual
http://www.servicematters.com/maytag...s/S231_2R1.pdf
And finally a tech bulletin which may apply.
http://www.servicematters.com/maytag...DC-0044A-B.pdf
Looks like there were heat issues but it was probably blowing boards.
Unplug the unit.
Does sound like a bad connection somewhere in the unit, the trick will be finding it.
If the unit has a cooling fan make sure it is working.
Check all connections going to and on the control board.
Check them for tightness, pitting and discoloration.
__________________
  #3 (permalink)
Old 02-01-2010, 05:12 AM
Junior Member
Default
Hello Denman,
It took some time to find it, but you were correct.The neutral,feeding the
controller,was loose inside the multi-pin connector. I couldn't get a good
connection so I soldered the wire straight to the board. Works like new.
Thanks for your help,
Midwayyankee
  #4 (permalink)
Old 02-01-2010, 05:22 AM
Senior Expert
APP Volunteer
Default
Glad to hear you found it
Thanks for getting back to us, your solution may well help others with this type of problem.
__________________
  #5 (permalink)
Old 10-21-2011, 07:50 PM
Junior Member
phooey2000 is on a distinguished road
Default Can you give more detail about the neutral with controller?
Midwayyankee or denman, I believe I am having the same exact problem with my Amana oven. I bought a new motor (I was lucky enough to find one and think I might have found the last one!) and new control limiters. I installed them but still had the same issue with oven shutting down. Tested the fan with test cord and it's working. In fact the old fan works even. Now I think I have the same problem midwayyankee did. However, I don't understand which part he's talking about. Could you be more specific about the neutral feeding to the controller?
I sure am glad I found this forum. I don't have the money to buy another oven right now and have hope I won't have to.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
No Display on Electronic Oven Controller/Clock who_dat Oven Repair (including Ranges and Cooktops) 5 01-31-2010 07:43 AM
Ice and Water Controller arashlal Refrigerator & Freezer Repair 0 12-28-2009 03:57 PM
Dryer Controller (2) robo1961 Dryer Repair 0 06-24-2009 10:41 AM
Dryer Controller robo1961 Dryer Repair 0 06-23-2009 04:36 PM
Changing Controller chrisa Oven Repair (including Ranges and Cooktops) 1 04-19-2009 04:33 PM
