Discuss
Frigidaire Double Oven Won't heat up
 in
I have a Frigidaire GLEB30T9FBA Double Oven. The lower unit will not heat up past 200 degrees. I have swapped
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Frigidaire Double Oven Won't heat up
  #1 (permalink)
Old 01-30-2010, 08:20 AM
Junior Member
mdbaker is on a distinguished road
Default Frigidaire Double Oven Won't heat up
Model Number: GLEB30T9FBA   Brand: Frigidaire   Age: 1 - 5 years
I have a Frigidaire GLEB30T9FBA Double Oven. The lower unit will not heat up past 200 degrees. I have swapped the elements from the lower unit with the upper unit. The elements work fine in the upper unit. I ordered an EOC and installed it, there was no change in the lower unit. I ordered a Relay Board and changed it, there was no change in the lower unit. I checked the temperature probe and measured 1056 ohms at 70 degrees F. Is there anything else I can check?
Ads By Google
Related Models
Frigidaire GLEB30T9FBA Frigidaire/walloven
Frigidaire GLEB30T9FBB Frigidaire/walloven
Frigidaire GLEB30T9FBC WALLOVEN
Frigidaire GLEB30T9FQA Frigidaire/walloven
Frigidaire GLEB30T9FQB Frigidaire/walloven
Frigidaire GLEB30T9FSA Frigidaire/walloven
Frigidaire GLEB30T9FSB Frigidaire/walloven
Frigidaire GLEB30T9FSC WALLOVEN
Frigidaire GLEC30S8ABB Frigidaire/electric Cooktop
Frigidaire GLEC30S8ABC Frigidaire/electric Cooktop
Frigidaire GLEC30S8AQA Frigidaire/cooktop
Frigidaire GLEC30S8AQB Frigidaire/electric Cooktop
Frigidaire GLEC30S8AQC Frigidaire/electric Cooktop
Frigidaire GLEC30S8ASA Frigidaire/cooktop
Frigidaire GLEC30S8ASB Frigidaire/electric Cooktop
Frigidaire GLEC30S8ASC Frigidaire/electric Cooktop
Frigidaire GLEC30S8CBA Frigidaire/electric Cooktop
Frigidaire GLEC30S8CBB Frigidaire/electric Cooktop
Frigidaire GLEC30S8CBC Frigidaire/electric Cooktop
Frigidaire GLEC30S8CQA Frigidaire/electric Cooktop
Frigidaire GLEC30S8CQB Frigidaire/electric Cooktop
Frigidaire GLEC30S8CQC Frigidaire/electric Cooktop
Frigidaire GLEC30S8CSA Frigidaire/electric Cooktop
Frigidaire GLEC30S8CSB Frigidaire/electric Cooktop
Frigidaire GLEC30S8CSC Frigidaire/electric Cooktop
Frigidaire GLEC30S8EB1 COOKTOP
Frigidaire GLEC30S8EBA Frigidaire/cooktop
Frigidaire GLEC30S8EBB Frigidaire/cook Top
Frigidaire GLEC30S8EQ1 COOKTOP
Frigidaire GLEC30S8EQA Frigidaire/cooktop
Frigidaire GLEC30S8EQB Frigidaire/cook Top
Frigidaire GLEC30S8ES1 COOKTOP
Frigidaire GLEC30S8ESA Frigidaire/cooktop
Frigidaire GLEC30S8ESB Frigidaire/cook Top
Frigidaire GLEC30S9EBA Frigidaire/electric Cooktop
Frigidaire GLEC30S9EBB Frigidaire/electric Cooktop
Frigidaire GLEC30S9EBC Frigidaire/cooktop
Frigidaire GLEC30S9EQA Frigidaire/electric Cooktop
Frigidaire GLEC30S9EQB Frigidaire/electric Cooktop
Frigidaire GLEC30S9EQC Frigidaire/cooktop
Frigidaire GLEC30S9ESA Frigidaire/electric Cooktop
Frigidaire GLEC30S9ESB Frigidaire/electric Cooktop
Frigidaire GLEC30S9ESC Frigidaire/cooktop
Frigidaire GLEC36S8ABA Frigidaire/cooktop
Frigidaire GLEC36S8ABB Frigidaire/electric Cooktop
Frigidaire GLEC36S8ABC Frigidaire/electric Cooktop
Frigidaire GLEC36S8AQA Frigidaire/cooktop
Frigidaire GLEC36S8AQB Frigidaire/electric Cooktop
Frigidaire GLEC36S8AQC Frigidaire/electric Cooktop
Frigidaire GLEC36S8ASA Frigidaire/cooktop
Frigidaire GLEC36S8ASB Frigidaire/electric Cooktop
Frigidaire GLEC36S8ASC Frigidaire/electric Cooktop
Frigidaire GLEC36S8CBA Frigidaire/electric Cooktop
Frigidaire GLEC36S8CBB Frigidaire/electric Cooktop
Frigidaire GLEC36S8CBC Frigidaire/electric Cooktop
Frigidaire GLEC36S8CQA Frigidaire/electric Cooktop
Frigidaire GLEC36S8CQB Frigidaire/electric Cooktop
Frigidaire GLEC36S8CQC Frigidaire/electric Cooktop
Frigidaire GLEC36S8CSA Frigidaire/electric Cooktop
Frigidaire GLEC36S8CSB Frigidaire/electric Cooktop
Frigidaire GLEC36S8CSC Frigidaire/electric Cooktop
Frigidaire GLEC36S8EB1 FRIGIDAIRE/COOKTOP
Frigidaire GLEC36S8EBA Frigidaire/cooktop
Frigidaire GLEC36S8EBB Frigidaire/cooktop
Frigidaire GLEC36S8EQ1 FRIGIDAIRE/COOKTOP
Frigidaire GLEC36S8EQA Frigidaire/cooktop
Frigidaire GLEC36S8EQB Frigidaire/cooktop
Frigidaire GLEC36S8ES1 FRIGIDAIRE/COOKTOP
Frigidaire GLEC36S8ESA Frigidaire/cooktop
Frigidaire GLEC36S8ESB Frigidaire/cooktop
Frigidaire GLEC36S9EBA Frigidaire/electric Cooktop
Frigidaire GLEC36S9EBB Frigidaire/electric Cooktop
Frigidaire GLEC36S9EBC Frigidaire/cooktop
Frigidaire GLEC36S9EQA Frigidaire/electric Cooktop
Frigidaire GLEC36S9EQB Frigidaire/electric Cooktop
Frigidaire GLEC36S9EQC Frigidaire/cooktop
Frigidaire GLEC36S9ESA Frigidaire/electric Cooktop
Frigidaire GLEC36S9ESB Frigidaire/electric Cooktop
Frigidaire GLEC36S9ESC Frigidaire/cooktop
Frigidaire GLED388ASA Frigidaire/electric Range
Frigidaire GLED388ASB Frigidaire/electric Range
Frigidaire GLED388ASC Frigidaire/electric Range
Frigidaire GLED388ASD Frigidaire/electric Range
Frigidaire GLED388CSA Frigidaire/electric Range
Frigidaire GLED388CSB Frigidaire/electric Range
Frigidaire GLED388DBA Frigidaire/electric Range
Frigidaire GLED388DBB Frigidaire/electric Range
Frigidaire GLED388DQA Frigidaire/electric Range
Frigidaire GLED388DQB Frigidaire/electric Range
Frigidaire GLED388DSA Frigidaire/electric Range
Frigidaire GLED388DSB Frigidaire/electric Range
Frigidaire GLEF369DBA Frigidaire/electric Range
Frigidaire GLEF369DBB Frigidaire/electric Range
Frigidaire GLEF369DBD Frigidaire/electric Range
Frigidaire GLEF369DBF Frigidaire/range
Frigidaire GLEF369DBG Frigidaire/range
Frigidaire GLEF369DBH Frigidaire/electric Range
Frigidaire GLEF369DBJ Frigidaire/range
Frigidaire GLEF369DBK ELECTRIC RANGE
Frigidaire GLEF369DCA Frigidaire/electric Range
Frigidaire GLEF369DCB Frigidaire/electric Range
Frigidaire GLEF369DCC Frigidaire/electric Range
Frigidaire GLEF369DCD Frigidaire/range
Frigidaire GLEF369DCF Frigidaire/range
Frigidaire GLEF369DCG Frigidaire/range
Frigidaire GLEF369DCH Frigidaire/range
Frigidaire GLEF369DCJ Frigidaire/range
Frigidaire GLEF369DQA Frigidaire/electric Range
Frigidaire GLEF369DQB Frigidaire/electric Range
Frigidaire GLEF369DQD Frigidaire/electric Range
Frigidaire GLEF369DQF Frigidaire/range
Frigidaire GLEF369DQG Frigidaire/range
Frigidaire GLEF369DQH Frigidaire/electric Range
Frigidaire GLEF369DQJ Frigidaire/range
Frigidaire GLEF369DSA Frigidaire/electric Range
Frigidaire GLEF369DSB Frigidaire/electric Range
Frigidaire GLEF369DSD Frigidaire/electric Range
Frigidaire GLEF369DSF Frigidaire/range
Frigidaire GLEF369DSG Frigidaire/range
Frigidaire GLEF369DSH Frigidaire/electric Range
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
frigidaire electric double oven jjmj Oven Repair (including Ranges and Cooktops) 0 11-24-2009 10:06 AM
F8 Error on Frigidaire Double Electric Oven Elizabeth Varjas Oven Repair (including Ranges and Cooktops) 0 05-25-2009 08:57 AM
frigidaire electrolux double oven hobitdor Oven Repair (including Ranges and Cooktops) 1 03-17-2009 07:40 PM
Frigidaire Double Oven John Boyce Oven Repair (including Ranges and Cooktops) 3 08-22-2008 08:38 AM
F8 error Frigidaire double oven jps Oven Repair (including Ranges and Cooktops) 3 12-20-2007 01:14 PM
