Discuss
heating element sparks and fire
 in
Hi, the heating element at the bottom of the stove started sparking, glowing then flaming up in one spot. i
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » heating element sparks and fire
  #1 (permalink)
Old 01-29-2010, 06:56 AM
Junior Member
stevemaria is on a distinguished road
Default heating element sparks and fire
Model Number: cer3760aaw   Brand: Magic Chef   Age: More than 10 years
Hi, the heating element at the bottom of the stove started sparking, glowing then flaming up in one spot. i shut down power, when cool element looks like rough and bubbly like it was welded. is this something I could replace and do you have a part # ???. Thanks for any help .
Related Models
Magic Chef CER3760AAW RANGE- S/C F/S ELE
Magic Chef CER3760ACA RANGE- S/C F/S ELE
Magic Chef CER3760ACQ RANGE- S/C F/S ELE
Magic Chef CER3760ACW RANGE- S/C F/S ELE
Admiral CER3760AGH RANGE- S/C F/S ELE
Magic Chef CER3760AGW RANGE- S/C F/S ELE
Magic Chef CER3760BAC RANGE- S/C F/S ELE
Magic Chef CER3760BAH RANGE- S/C F/S ELE
Magic Chef CER3760BAQ RANGE- S/C F/S ELE
Magic Chef CER3760BAT RANGE- S/C F/S ELE
Magic Chef CER3760BAW RANGE- S/C F/S ELE
Admiral CER3760BGW RANGE- S/C F/S ELE
Magic Chef CER3765AAC RANGE- S/C F/S ELE
Admiral CER4351AGW RANGE- S/I STD ELE
Maytag CERS858TCD0 30" ELECTRIC CERAN FREESTANDING RANGE SELF CLEAN OVEN
Maytag CERS858TCW0 30" ELECTRIC CERAN FREESTANDING RANGE SELF CLEAN OVEN
Amana CES1092HR ROOM AIR CONDITIONER
Amana CES1092HS ROOM AIR CONDITIONER
Amana CES1093HER ROOM AIR CONDITIONER
Amana CES1093HES ROOM AIR CONDITIONER
Magic Chef CES1110AAH RANGE- S/C S/I ELE
Amana CES1123HER ROOM AIR CONDITIONER
Amana CES1123HES ROOM AIR CONDITIONER
Amana CES1123R ROOM AIR CONDITIONER
Amana CES1123S ROOM AIR CONDITIONER
Magic Chef CES1350AAH RANGE- S/C S/I ELE
Amana CES2183HER ROOM AIR CONDITIONER
Amana CES2183HES ROOM AIR CONDITIONER
Magic Chef CES3540AAC RANGE- S/C S/I ELE
Magic Chef CES3540AAW RANGE- S/C S/I ELE
Magic Chef CES3540ACB Range - S/c S/i Ele
Magic Chef CES3540ACC RANGE- S/C S/I ELE
Magic Chef CES3540ACW RANGE- S/C S/I ELE
Whirlpool CES365HQ0 ELECTRIC RANGE
Whirlpool CES365HQ1 ELECTRIC RANGE
Whirlpool CES365HZ0 ELECTRIC RANGE
Whirlpool CES365HZ1 ELECTRIC RANGE
Whirlpool CES366HQ0 Electric Free Standing Range
Whirlpool CES366HQ1 Electric Free Standing Range
Whirlpool CES366HZ0 Electric Free Standing Range
Whirlpool CES366HZ1 Electric Free Standing Range
Magic Chef CES3759BCB RANGE- S/C S/I ELE
Magic Chef CES3759BCS RANGE- S/C S/I ELE
Magic Chef CES3759BCW RANGE- S/C S/I ELE
Magic Chef CES3760AAA RANGE- S/C S/I ELE
Magic Chef CES3760AAB RANGE- S/C S/I ELE
Magic Chef CES3760AAQ RANGE- S/C S/I ELE
Magic Chef CES3760AAW RANGE- S/C S/I ELE
Amana CET-480 RANGE- S/C S/I DDRAFT GAS
Whirlpool CET08E1A1 Air-conditioner/heat pump
Whirlpool CET14D2A1 Air-conditioner/heat pump
Whirlpool CET18C2A1 Air-conditioner/heat pump
Thermador CET304ZB
Thermador CET304ZW
Thermador CET365ZB
Thermador CET365ZW
Whirlpool CET8000XQ0 COMMERCIAL STACKED ELECTRIC DRYER/WASHER
Amana CEU-516 RANGE- S/C S/I DDRAFT GAS
Whirlpool CEW2760AN0 COMMERCIAL ELECTRIC DRYER
Whirlpool CEW2760AN1 COMMERCIAL ELECTRIC DRYER
Whirlpool CEW2760AW0 COMMERCIAL ELECTRIC DRYER
Whirlpool CEW2760AW1 COMMERCIAL ELECTRIC DRYER
Whirlpool CEW2760EW0 DRYERS
Whirlpool CEW2790EW0 DRYERS
Crosley CEW2C3 RANGE- F/S STD ELE
Crosley CEW2D2 RANGE- F/S STD ELE
 CEW30DF6GBC RANGE
 CEW30DF6GBD RANGE
 CEW30DF6GSB RANGE
 CEW30DF6GSC RANGE
 CEW30DF6GSD RANGE
 CEW30DF6GSE RANGE
 CEW30DF6GSG RANGE
 CEW30DF6GSH RANGE
 CEW30DF6GSJ RANGE
 CEW30DF6GSK RANGE
 CEW30DF6GWC RANGE
 CEW30DF6GWD RANGE
 CEW30EF6GBC RANGE
 CEW30EF6GBD RANGE
 CEW30EF6GBE RANGE
 CEW30EF6GSB RANGE
 CEW30EF6GSC RANGE
 CEW30EF6GSD RANGE
 CEW30EF6GSE RANGE
 CEW30EF6GSF RANGE
 CEW30EF6GSG RANGE
 CEW30EF6GSH RANGE
 CEW30EF6GSJ RANGE
 CEW30EF6GWC RANGE
 CEW30EF6GWD RANGE
 CEW30EF6GWE RANGE
 CEW30GF6GBB RANGE
 CEW30GF6GBC RANGE
 CEW30GF6GBD RANGE
 CEW30GF6GSB RANGE
 CEW30GF6GSC RANGE
 CEW30GF6GSD RANGE
 CEW30GF6GSE RANGE
 CEW30GF6GSF RANGE
 CEW30GF6GSG RANGE
 CEW30GF6GSH RANGE
 CEW30GF6GSJ RANGE
 CEW30GF6GWB RANGE
 CEW30GF6GWC RANGE
 CEW30GF6GWD RANGE
 CEW30IF6ISA ELECTRIC RANGE
Magic Chef CEW3330AAB WALLOVEN- S/C ELE
Magic Chef CEW3330AAW WALLOVEN- S/C ELE
Magic Chef CEW3330ACB WALLOVEN- S/C ELE
Magic Chef CEW3330ACW WALLOVEN- S/C ELE
Crosley CEW3C6CV RANGE- F/S STD ELE
Crosley CEW3D1 RANGE- F/S STD ELE
Crosley CEW3D1X RANGE- F/S STD ELE
Crosley CEW3D3D RANGE- F/S STD ELE
Crosley CEW3D3W RANGE- F/S STD ELE
Crosley CEW3D3X RANGE- F/S STD ELE
Crosley CEW3D5DLV RANGE- F/S CONT CLEAN ELE
Crosley CEW3D5DLW RANGE- F/S CONT CLEAN ELE
  #2 (permalink)
Old 01-29-2010, 07:32 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
Do not use the oven till the element is replaced as you could blow the control board. With a little luck the board is still OK
Replacement parts for MAGIC CHEF CER3760AAW Range - S/c F/s Ele | AppliancePartsPros.com
Yes you should be able to replace it your self.
Unplug the unit.
Remove the racks from the oven.
There is usually 1 or 2 screws holding the element bracket to the back of the oven.
Remove it/them.
Gently pull the element forward till the connectors/wires for the element are in the oven.
Remove the wires from the element.
It is a good idea to clip something (clothespin etc.) onto the wires so they do not disappear behind the back of the stove,
Also a good idea to check the old element against the new one just to be sure the element legs that go into the back of the stove are not longer than the original.
Connect the wires to the new element and gently push it back in.
Re-install the screws and you should be away to the races.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Replaced heating element now heating element nor broil element work, all else does rontetley Oven Repair (including Ranges and Cooktops) 1 10-26-2009 01:30 PM
Element Catches Fire Karma Oven Repair (including Ranges and Cooktops) 0 08-17-2009 01:06 PM
One range element not heating after oil fire Rich777 Oven Repair (including Ranges and Cooktops) 3 06-15-2009 07:36 PM
heating element on fire 1Julie Oven Repair (including Ranges and Cooktops) 0 12-26-2008 03:47 PM
Sparks from heater element blibby Dryer Repair 1 09-28-2008 11:42 AM
