Discuss
Please help
 in
I believe I have a problem with a relay. Every thing seems to be working properly on the clock and
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Please help
  #1 (permalink)
Old 01-29-2010, 06:25 AM
Junior Member
yror is on a distinguished road
Question Please help
Model Number: svd48600w   Brand: Jenn-Air   Age: 5 - 10 years
I believe I have a problem with a relay. Every thing seems to be working properly on the clock and display. When you select bake, broil convect bake etc. it shows on the display and the temperature selected also shows up. The display then switches to preheat showing 100 but does not start to heat. I can hear a slight sound like a hum/whistle that comes on approx 15 seconds then goes off for approx 5 seconds and keeps repeating this sequence. The sound seems to be coming from the back side of the oven near the top. The last couple weeks is when it started acting up. Somtimes you could only get it to heat by selecting broil. Other times convect bake wouln't work but bake would and then if you switched it to convect after it started to heat with the bake setting it would continue to work with the convect bake the rest of the cooking time. I would appreciate any advice so I know the correct part to order and how big a job it is to replace.
Ads By Google
Related Models
Jenn-Air SVD48600W Range - S/c S/i Gas & Elec Duel Fuel
Jenn-Air SVD48600WC Range - S/c S/i Gas & Elec Duel Fuel
Jenn-Air SVD8310S Range - S/c S/i Gas & Elec Duel Fuel
Jenn-Air SVD8310S-C Range - S/c S/i Gas & Elec Duel Fuel
Jenn-Air SVD8310SD Range - S/c S/i Gas & Elec Duel Fuel
Jenn-Air SVD8310SF Range - S/c S/i Gas & Elec Duel Fuel
Jenn-Air SVD8310SG Range - S/c S/i Gas & Elec Duel Fuel
Jenn-Air SVD8310SK Range - S/c S/i Gas & Elec Duel Fuel
Jenn-Air SVD8310SR Range - S/c S/i Gas & Elec Duel Fuel
Jenn-Air SVD8310SU Range - S/c S/i Gas & Elec Duel Fuel
Jenn-Air SVE47100B Range - S/c S/i Ddraft Ele
Jenn-Air SVE47100BC Range - S/c S/i Ddraft Ele
Jenn-Air SVE47100W Range - S/c S/i Ddraft Ele
Jenn-Air SVE47100WC Range - S/c S/i Ddraft Ele
Jenn-Air SVE47500B Range - S/c S/i Ddraft Ele
Jenn-Air SVE47500W Range - S/c S/i Ddraft Ele
Jenn-Air SVE47600B Range - S/c S/i Ddraft Ele
Jenn-Air SVE47600BC Range - S/c S/i Ddraft Ele
Jenn-Air SVE47600W Range - S/c S/i Ddraft Ele
Jenn-Air SVE47600WC Range - S/c S/i Ddraft Ele
Jenn-Air SVE87600B Range - S/c S/i Ddraft Ele
Jenn-Air SVE87600W Range - S/c S/i Ddraft Ele
Whirlpool SVF100W0
Whirlpool SVF100W1
Whirlpool SVF12FRHW00
Whirlpool SVF15NRHW00
Whirlpool SVF15NRHW01
Whirlpool SVF15NRHW02
Whirlpool SVF15NRJW00
Whirlpool SVF20NRKQ00
Whirlpool SVF60W0
Whirlpool SVF60W1
Whirlpool SVF70W0
Whirlpool SVF70W1
Whirlpool SVF75W0
Whirlpool SVF75W1
Whirlpool SVF75W2
Whirlpool SVF80W0
Whirlpool SVF80W1
Whirlpool SVF90W0
Whirlpool SVF90W1
Whirlpool SVP100W0
Whirlpool SVP50W0
Whirlpool SVP60W0
Whirlpool SVP60W1
Whirlpool SVP70W0
Whirlpool SVP75W0
Whirlpool SVP80W0
Whirlpool SVP90W0
Whirlpool SVU100W0
Whirlpool SVU100W1
Whirlpool SVU100W2
Whirlpool SVU60W0
Whirlpool SVU60W1
Whirlpool SVU60W2
Whirlpool SVU70W0
Whirlpool SVU70W1
Whirlpool SVU70W2
Whirlpool SVU80W0
Whirlpool SVU80W1
Whirlpool SVU80W2
Whirlpool SVU90W0
Whirlpool SVU90W1
Whirlpool SVU90W2
Amana SW22H Ref - SXS/I&W
Amana SW22MBG Ref - SXS/I&W
Amana SW22MBL Ref - SXS/I&W
Amana SW22MBW Ref - SXS/I&W
Amana SW25H Ref - SXS/I&W
Amana SWDT22H Ref - SXS/I&W
Amana SWDT25H Ref - SXS/I&W
Whirlpool SWF100W0
Whirlpool SWF100W2
Whirlpool SWF60W0
Whirlpool SWF60W2
Whirlpool SWF70W0
Whirlpool SWF70W2
Whirlpool SWF80W0
Whirlpool SWF80W2
Whirlpool SWF80W8
Whirlpool SWF80W9
Whirlpool SWF90W0
Whirlpool SWF90W1
Whirlpool SWF90W2
Amana SWP25H Ref - SXS/I&W
Whirlpool SWP70W0
Whirlpool SWP80W0
Whirlpool SWP90W0
Amana SWPD25H Ref - SXS/I&W
White Westinghouse SWS1233CQ0 White Westinghouse/washer
White Westinghouse SWS1233CQ1 White Westinghouse/washer
White Westinghouse SWS1233CS0 White Westinghouse/washer
White Westinghouse SWS1233CS1 White Westinghouse/washer
White Westinghouse SWS1339CC1 White Westinghouse/washer
White Westinghouse SWS1339CC2 White Westinghouse/washer
White Westinghouse SWS1549AQ0 Washer - W.westinghouse
White Westinghouse SWS1549AQ1 Washer - West/grupo Famsa
White Westinghouse SWS1549AQ2 White Westinghouse/washer
White Westinghouse SWS1549AS0 Washer - W.westinghouse
White Westinghouse SWS1549AS1 Washer - West/grupo Famsa
White Westinghouse SWS1549AS2 White Westinghouse/washer
White Westinghouse SWS1649CQ0 White Westinghouse/washer
White Westinghouse SWS1649CQ1 White Westinghouse/washer
White Westinghouse SWS1649CS0 White Westinghouse/washer
White Westinghouse SWS1649CS1 White Westinghouse/washer
White Westinghouse SWS933AQ0 Washer - W.westinghse
White Westinghouse SWS933AQ1 Washer - West/grupo Famsa
White Westinghouse SWS933AQ2 White Westinghouse/washer
White Westinghouse SWS933AS0 Washer - W.westinghse
White Westinghouse SWS933AS1 Washer - West/grupo Famsa
White Westinghouse SWS933AS2 White Westinghouse/washer
White Westinghouse SWSG1031DQ0 White Westinghouse/laundry Center
White Westinghouse SWSG1031DQ1 White Westinghouse/laundry Center
White Westinghouse SWSG1031DS0 White Westinghouse/laundry Center
White Westinghouse SWSG1031DS1 White Westinghouse/laundry Center
  #2 (permalink)
Old 01-29-2010, 07:35 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
Thought I had already replied to this.
see the following link
oven problem with model number
Or if you are just looking for more opinions please re-post and I will ignore it.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
