Discuss
Monitor light does not come on.
 in
I have a Moden Maid wall gas oven. The monitor turn on light does not come on. The inside bulb
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Monitor light does not come on.
  #1 (permalink)
Old 04-17-2008, 12:43 PM
Junior Member
tenoral is on a distinguished road
Default Monitor light does not come on.
Brand: Modern Maid   Age: Less than 1 year
I have a Moden Maid wall gas oven. The monitor turn on light does not come on. The inside bulb is working. The unit must be over 30 years old. I can not read the model number. Any suggestions as to the way to trouble shoot the problem? Thanks
Ads By Google
  #2 (permalink)
Old 04-18-2008, 10:51 AM
Senior Expert
APP Volunteer
glen65 is on a distinguished road
Default
I take it that the oven heats ok?
If the oven is that old then they probably used a
neon or small incandescent bulb. You need to
check for AC voltage at the two terminals that the
indicator lamp connects to. You can check it
with a volt meter. But if don’t know how to use –or
have one you can also use a simple test light for this.
(not the automotive type)
This type-they can be had for about 5 dollars at the hardware store.
If you get voltage (or the test light comes on) then
you need to replace the indicator light bulb itself.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
cycle monitor stuck on clean.. LATONYA007 Dishwasher Repair 6 11-23-2011 02:44 AM
Replace program monitor drive akfixit Dishwasher Repair 4 11-25-2008 09:29 PM
