Discuss
Oven Ignitor Doesn't Work
 in
My wall oven does not go on when I turn the knob. I noticed that the metal ignitor that sticks
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Oven Ignitor Doesn't Work
  #1 (permalink)
Old 01-27-2010, 06:02 AM
Junior Member
SKRosen1 is on a distinguished road
Default Oven Ignitor Doesn't Work
Model Number: 9112WPA   Brand: Magic Chef   Age: 5 - 10 years
My wall oven does not go on when I turn the knob. I noticed that the metal ignitor that sticks out of the roof of the interior of the oven is not attached on one side. If this is the problem (and I am assuming it probably is), I need to know how to get into the oven in order to reconnect the part if possible, or replace the part if necessary. Are there any instructions you can give me to diagnose and gain access to the part. Thank you.
Ads By Google
Related Models
Magic Chef 9112WPA Walloven - Std Gas
Magic Chef 9112WPW Walloven - Std Gas
Magic Chef 9112WUA Walloven - Std Gas
Magic Chef 9112WUT Walloven - Std Gas
Magic Chef 9112WUV Walloven - Std Gas
Magic Chef 9112XPB Walloven - Std Gas
Magic Chef 9112XUB Walloven - Std Gas
Kenmore 9113012990 GAS OVEN
Kenmore 9113012991 24" GAS BUILT-IN OVEN
Kenmore 9113012992 24" GAS BUILT-IN OVEN
Kenmore 91130158590 24" GAS BUILT-IN OVEN
Kenmore 91130168690 24" GAS BUILT-IN OVEN
Kenmore 91130168791 24" GAS BUILT-IN OVEN
Kenmore 91130168792 24" GAS BUILT-IN OVEN
Kenmore 91130168894 GAS BUILT-IN OVEN
Kenmore 91130169690 24"(GAS BUILT-IN OVEN
Kenmore 91130169791 24" GAS BUILT-IN OVEN
Kenmore 91130169792 24" GAS BUILT-IN OVEN
Kenmore 91130169894 GAS BUILT-IN OVEN
Kenmore 9113018892 GAS BUILT-IN OVEN
Kenmore 9113022190 Wall Oven, Gas
Kenmore 9113022191 24" GAS BUILT-IN OVEN
Kenmore 9113022192 24" GAS BUILT-IN OVEN
Kenmore 9113022990 GAS OVEN
Kenmore 9113022991 24" GAS BUILT-IN OVEN
Kenmore 9113022992 24" GAS BUILT-IN OVEN
Kenmore 9113042590 GAS WALL OVENS
Kenmore 9113042591 EXTENDED DELAYED IGNITION-SELF CLEAN.GAS WALL OVEN
Kenmore 9113042592 EXTENDED DELAYED IGNITION-SELF CLEAN.GAS WALL OVEN
Kenmore 9113042593 EXTENDED DELAYED IGNITION-SELF CLEAN.GAS WALL OVEN
Kenmore 9113042990 ERC TOUCH PADS HARD TO PUSH/F2 CODE-GAS WALL OVENS
Kenmore 9113042991 EXTENDED DELAYED IGNITION-SELF CLEAN.GAS WALL OVEN
Kenmore 9113042992 EXTENDED DELAYED IGNITION-SELF CLEAN.GAS WALL OVEN
Kenmore 9113042993 EXTENDED DELAYED IGNITION-SELF CLEAN.GAS WALL OVEN
Kenmore 91130465690 EXTENDED DELAYED IGNITION-SELF CLEAN.GAS WALL OVEN
Kenmore 91130465791 EXTENDED DELAYED IGNITION-SELF CLEAN.GAS WALL OVEN
Kenmore 91130465792 24" GAS BUILT-IN OVEN
Kenmore 91130465893 24" GAS BUILT-IN OVEN
Kenmore 91130465894 GAS BUILT-IN OVEN
Kenmore 91130469690 EXTENDED DELAYED IGNITION-SELF CLEAN.GAS WALL OVEN
Kenmore 91130469791 EXTENDED DELAYED IGNITION-SELF CLEAN.GAS WALL OVEN
Kenmore 91130469792 24" GAS BUILT-IN OVEN
Kenmore 91130469893 24" GAS BUILT-IN OVEN
Kenmore 91130469894 GAS BUILT-IN OVEN
Kenmore 9113118892 GAS BUILT-IN OVEN
Kenmore 9113128812 GAS BUILT-IN OVEN
Kenmore 9113128892 GAS BUILT-IN OVEN
Kenmore 9113138818 EXTENDED DELAYED IGNITION-SELF CLEAN.GAS WALL OVEN
Kenmore 9113138819 EXTENDED DELAYED IGNITION-SELF CLEAN.GAS WALL OVEN
Kenmore 9113138890 EXTENDED DELAYED IGNITION-SELF CLEAN.GAS WALL OVEN
Kenmore 9113138891 EXTENDED DELAYED IGNITION-SELF CLEAN.GAS WALL OVEN
Kenmore 9113138898 EXTENDED DELAYED IGNITION-SELF CLEAN.GAS WALL OVEN
Kenmore 9113138899 EXTENDED DELAYED IGNITION-SELF CLEAN.GAS WALL OVEN
Kenmore 9113302090 36" GAS COUNTER UNIT
Kenmore 9113302190 36" GAS COUNTER UNIT
Kenmore 9113312591 GAS COUNTER UNIT
Kenmore 9113312592 GAS COUNTER UNIT
Kenmore 9113312593 GAS COUNTER UNIT
Kenmore 9113312991 GAS COUNTER UNIT
Kenmore 9113312992 GAS COUNTER UNIT
Kenmore 9113312993 GAS COUNTER UNIT
Kenmore 91133202100 30" GAS COOKTOP
Kenmore 91133202101 30" GAS COOKTOP
Kenmore 91133203100 30" GAS COOKTOP
Kenmore 91133203101 30" GAS COOKTOP
Kenmore 91133204100 30" GAS COOKTOP
Kenmore 91133204101 30" GAS COOKTOP
Kenmore 91133209100 30" GAS COOKTOP
Kenmore 91133209101 30" GAS COOKTOP
Kenmore 91133212100 COOKTOP
Kenmore 91133212101 36" GAS COOKTOP
Kenmore 91133213100 36" GAS COOKTOP
Kenmore 91133213101 36" GAS COOKTOP
Kenmore 91133214100 36" GAS COOKTOP
Kenmore 91133219100 COOKTOP
Kenmore 91133219101 36" GAS COOKTOP
Kenmore 91133255590 RANGE
Kenmore 91133255591 36" GAS COUNTER UNIT
Kenmore 91133255592 36" GAS COUNTER UNIT
Kenmore 91133259590 RANGE
Kenmore 91133259591 36" GAS COUNTER UNIT
Kenmore 91133285091 COOKTOP
Kenmore 91133285890 36" GAS COUNTER UNIT
Kenmore 91133289091 COOKTOP
Kenmore 91133289890 36" GAS COUNTER UNIT
Kenmore 91133355590 RANGE
Kenmore 91133355591 36" GAS COUNTER UNIT
Kenmore 91133355592 36" GAS COUNTER
Kenmore 91133356590 RANGE
Kenmore 91133356591 36" GAS COUNTER UNIT
Kenmore 91133359590 RANGE
Kenmore 91133359591 36" GAS COUNTER UNIT
Kenmore 91133384100 36" GAS COOKTOP
Kenmore 91133384101 36" GAS COOKTOP
Kenmore 91133385100 36" GAS COOKTOP
Kenmore 91133385890 36" GAS COUNTER UNIT
Kenmore 91133386890 36" GAS COUNTER UNIT
Kenmore 91133389100 36" GAS COOKTOP
Kenmore 91133389890 36" GAS COUNTER UNIT
Kenmore 9114012190 ELEC BUILT-IN OVEN
Kenmore 9114012191 ELEC BUILT-IN OVEN
Kenmore 9114012192 24" ELECTRIC BUILT-IN OVEN
Kenmore 9114012193 24" ELECTRIC BUILT-IN OVEN
Kenmore 9114012990 ELEC BUILT-IN OVEN
Kenmore 9114012991 ELEC BUILT-IN OVEN
Kenmore 9114012992 24" ELECTRIC BUILT-IN OVEN
Kenmore 9114012993 24" ELECTRIC BUILT-IN OVEN
Kenmore 91140161690 24" ELECTRIC BUILT-IN OVEN
Kenmore 91140161791 24" ELECTRIC BUILT-IN OVEN
Kenmore 91140161792 24" ELECTRIC BUILT-IN OVEN
Kenmore 91140168792 24" ELECTRIC BUILT-IN OVEN
Kenmore 91140169690 24" ELECTRIC BUILT-IN OVEN
Kenmore 91140169791 24" ELECTRIC BUILT-IN OVEN
Kenmore 91140169792 24" ELECTRIC BUILT-IN OVEN
Kenmore 9114018813 ELECTRIC BUIL-IN OVEN
Kenmore 9114018893 ELECTRIC BUIL-IN OVEN
Kenmore 9114028893 ELECTRIC BUIL-IN OVEN
Kenmore 9114038816 ELECTRIC BUILT IN OVEN
Kenmore 9114038896 ELECTRIC WALL OVEN
Kenmore 9114042590 ELEC. BUILT-IN OVEN
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Bake ignitor won't work but everything else does heldelhail Oven Repair (including Ranges and Cooktops) 0 01-25-2010 04:46 PM
Thermador cooktop ignitor does not work Homemaker909 Oven Repair (including Ranges and Cooktops) 0 11-15-2009 09:12 PM
Whirlpool oven won't work - replaced ignitor tradermon23 Oven Repair (including Ranges and Cooktops) 2 10-03-2008 06:47 PM
oven ignitor not clicking, but pilot will light manually and then the oven will work rosscol Oven Repair (including Ranges and Cooktops) 0 09-10-2008 05:37 PM
oven ignitor not clicking, but pilot will light manually and oven work then rosscol Oven Repair (including Ranges and Cooktops) 1 09-03-2008 04:30 PM
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
