| » Oven won't heat |
Model Number: MER5775QAB Brand: Maytag Age: 1 - 5 years
The oven won't heat past 200F. The temp probe was replaced with a part from your site, but I found the old one to be good by doing a resistance test (1150 ohms). Later my wife told me that the digital control panel was found to be out on 2 ocassions, but the cooktop burners still worked. The display would come back on randomly. I've done a hard reset, by tripping the circuit breaker, but it still won't heat. The broiler works and the cooktop burners work, but no oven heat. Even when this thing was new it would take 20 minutes to get to 350F which always seemed weak.
My question is, what other control element can be replaced, other than the entire control panel part number AP4100742? Do you think this is the next logical option. Thanks Related Models |
| Display Modes | |
| Wall oven will not heat/re-heat properly | dottavio | Oven Repair (including Ranges and Cooktops) | 0 | 01-07-2010 09:47 AM |
| Oven/clock Control Panel is no longer lit but oven does heat. | jthomas@abrakadoodle.com | Oven Repair (including Ranges and Cooktops) | 1 | 12-05-2009 04:07 PM |
| Oven broiler and burners work - oven will not heat | fatbuford | Oven Repair (including Ranges and Cooktops) | 0 | 11-27-2009 05:50 AM |
| Caloric double oven/bottom oven doesn't heat | kj0505 | Oven Repair (including Ranges and Cooktops) | 1 | 12-10-2008 09:14 AM |
| Bosch 27" Dbl oven Powering on but no heat either oven | badace | Oven Repair (including Ranges and Cooktops) | 0 | 12-02-2007 09:56 AM |
