Discuss
safety valve
 in
my new oven igniter does not glow. is this caused by a bad gas safety valve?? the igniter is powered
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » safety valve
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 04-15-2008, 03:13 PM
jakenepa jakenepa is offline
Junior Member
jakenepa is on a distinguished road
Default safety valve
Model Number: 30-2272-23/03   Brand: Tappan   Age: More than 10 years
my new oven igniter does not glow. is this caused by a bad gas safety valve?? the igniter is powered up and power goes on and off when the oven themostat is operated but no glow. i jumpered power over to gas safety valve to trouble shoot for bad igniter, before i ordered new igniter so did i cause safety valve failure?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 04-15-2008, 07:02 PM
gearhead1218 gearhead1218 is offline
Member
gearhead1218 is on a distinguished road
Default
You absolutely fried the safety valve if you put 120 volts to it.
120 volts is applied to the ignitor. The ignitor has resistance through it, glows and heats up, then with this resistance sends about 3.2 volts to the safety valve to open it.
  #3 (permalink)
Old 04-16-2008, 01:47 PM
Junior Member
Default
thank you for the response! so the safety valve is fried and now it breaks the circuit so the flat igniter will not glow, even though it has 120 volts supplied to it, the safety valve continues the circuit back to neutral.
  #4 (permalink)
Old 04-16-2008, 04:37 PM
Member
Default
Correct. Basically a series circuit.
Of course when you replaced the ignitor you only touched the ceramic section and wires, right. If you handled the part that glows, replace that new ignitor.
  #5 (permalink)
Old 04-17-2008, 06:04 PM
Junior Member
Default
that is correct i did not touch the element, i ordered a safety valve it should arrive on friday
  #6 (permalink)
Old 04-18-2008, 03:38 PM
Junior Member
Smile fixed
thanks again for your help! i installed the new safety valve today. the oven is now working!!!!
  #7 (permalink)
Old 04-18-2008, 05:31 PM
Member
Thumbs up
Excellent.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Safety concern homeuser Oven Repair (including Ranges and Cooktops) 0 03-28-2008 07:28 AM
Safety Repair Required After Sears Installation pagroundhog Oven Repair (including Ranges and Cooktops) 0 03-02-2008 04:54 AM
safety valve adepinto Oven Repair (including Ranges and Cooktops) 3 02-02-2008 07:08 PM
Need Safety valve for Gaffers and Sattler oven xuuly Oven Repair (including Ranges and Cooktops) 1 12-05-2007 01:59 PM
Safety Thermosta steve_a_mann Oven Repair (including Ranges and Cooktops) 0 09-30-2007 03:48 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
