My oven stopped working and is flashing twice on the oven indicator and then twice on the heating indicator. This happened as a result of trying to set upt the oven in the clean mode, which didn't work as the door did not lock and the heat did not go on. I had to trip the circuit breaker to stop the oven fan from running. What happened?:mad:
Hello, The 2/2 error is a bad control board, Thermador part number 676192. Usually, this is the result of a power surge or lightning strike, then there are the rare occasions when it occurs after a breaker reset.
KC
