Discuss
Relay board problem???
 in
My problem is 2 fold. 1st the LED's on the clock panel quit however all of the control functions
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Relay board problem???
  #1 (permalink)
Old 04-13-2008, 09:28 PM
Daryl66 Daryl66 is offline
Junior Member
Daryl66 is on a distinguished road
Default Relay board problem???
Model Number: SVE47600B   Brand: Jenn-Air   Age: 5 - 10 years
My problem is 2 fold. 1st the LED's on the clock panel quit however all of the control functions worked for almost a year, except the "broil". Dont know when it quite but all at once we could not broil.Would not heat. Then I started having trouble getting the "bake" function to work. Seemed you had to push real hard on the membrane switch to get it started. I replaced the clock yesterday and it now lights up great however all of the functions on the left side do not work. ie: bake, broil, clean,. The right side seems to work fine. "oven light" etc.
I then put the old clock back in and the led(s) still did not work and now the left side of the control panel does not work either. My first thought was the membrane switches, but after looking at the wiring diagram I now suspect relay(s). Your input is appreciated.
Daryl
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 04-14-2008, 04:17 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Quote:
Originally Posted by Daryl66 View Post
...I replaced the clock yesterday and it now lights up great however all of the functions on the left side do not work. ie: bake, broil, clean,. The right side seems to work fine. "oven light" etc...
Daryl
Daryl,
If no buttons respond (did not even "beep") - most likely the problem is a bad membrane switch.
Here are the break down diagrams for the Jenn Air range Model SVE47600B
__________________
Professional appliance repair in Los Angeles, California.
  #3 (permalink)
Old 04-14-2008, 06:04 PM
Junior Member
Default
Quote:
Originally Posted by Gene View Post
Daryl,
Gene: Thank you for your reply. The Membrane switch(s??) was my first thought and I have to admit that over the years the "Bake" and "Broil" were the only ones used. The convection oven functions were never or rarely used to my knowledge.
There is NO beep on ANY of the 5 buttons. The "timer lock" and "unlock" do beep and appear to function.
Not having a clue as to how this panel is constructed is it logical to think that 5 individual switches have failed??? or is there some commonality that you are aware of????
Daryl
  #4 (permalink)
Old 04-15-2008, 09:27 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Daryl,
If the membrane switch (aka touch pad or control panel) ribbon is plugged all the way into the control board (aka clock) then the problem is a bad membrane switch.
__________________
  #5 (permalink)
Old 04-15-2008, 10:30 PM
Junior Member
Default
Gene:
Found a repair manual and it sure looks like the ribbon cable at one end or the other is the culprit. Will try digging into it tomorrow. If I cannot repair it guess I will have to order a new control panel. Thanks
Daryl
  #6 (permalink)
Old 04-15-2008, 10:35 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Daryl,
Keep us posted.
__________________
  #7 (permalink)
Old 04-16-2008, 12:51 PM
Junior Member
Default
Gene: Well good news and bad news. The good news is I have confirmed(at least in my mind) that the #3 wire is broken, probably up in the touch pad. I jumpered (using the old clock) from 3 to 10 and sure enuff I got the beep. I cannot see any way to get into that panel. It appears that it is put together with a rubberized cement then baked or something like that. I guess the bad news is I now have to spring for the new control panel.
Many thanks.
Daryl
  #8 (permalink)
Old 04-18-2008, 02:29 PM
Junior Member
Default
New Membrane touch control pad arrived and installed. Everything works. Many thanks for your help
Daryl
  #9 (permalink)
Old 04-19-2008, 12:05 AM
Gene's Avatar
Senior Expert
APP Volunteer
Default
I'm glad you were able to fix it.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Possible compressor relay problem Pottspd Refrigerator & Freezer Repair 4 10-14-2008 09:36 PM
Control Board Problem? anacaparob Oven Repair (including Ranges and Cooktops) 7 01-24-2008 08:16 AM
Kitchenaid control board problem ieajrl Refrigerator & Freezer Repair 8 01-10-2008 03:21 AM
How to replace relay board? Marc Lombardini Oven Repair (including Ranges and Cooktops) 3 11-28-2007 09:15 AM
Thermador built in oven - relay board meganluk Oven Repair (including Ranges and Cooktops) 0 11-21-2007 06:21 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
